Old 07-28-2009, 06:39 PM   #1
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
replacing condensate drain tubing
In order to connect my existing condensate drain to my new carrier lo profile unit, I had to splice in a short piece of tubing with a tubing connector and 3 clamps. Does anyone know if the exising condensate drain tubing will pull out of the wall with new (longer) tubing attached to one end? I believe it would if not clamped, or attached to the AS in any way. What say ya'll?
bill the old newbie
wmarsha is offline   Reply With Quote
Removing & Replacing Shower Drain kentuvman Plumbing - Systems & Fixtures 8 07-22-2009 08:32 PM
replacing fresh water drain valve HeadnOut Fresh Water Systems 5 05-13-2009 10:19 PM
replacing fresh water tubing? stglmyr Fresh Water Systems 4 04-06-2008 07:49 AM
Condensate Drain mkeith54 All Argosy Trailers 3 08-18-2003 02:01 PM
'70's condensate drain? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 12 04-16-2003 07:05 PM
