Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-15-2006, 08:36 PM   #1
caadoptees
caadoptees's Avatar
Profile:  1992 25' Excella
Visalia , California
Images: 16
Send a message via AIM to caadoptees Send a message via MSN to caadoptees Send a message via Yahoo to caadoptees
Replacing air conditioner exhaust fin?
I think that is what you might call it. It is the vertical piece of aluminum that sits between the exhaust of the air conditioner and the vent for the refrigerator.
Here is the problem that we found. On the way to the International in Salem, we hit 117 degree weather in Redding. We were running our air conditioner (naturally) plus our refrigerator. Well the refrig wasn't doing real good. It was around 60 degrees and it normally does better than that at home during 100+ degrees. I was unsure what was happening since the refrigerator worked great before we left and it is less than 2 years old.
Sisters, OR was a bit cooler but we still had the same problem with the refrigerator. I got up to the top of the trailer and felt that the exhaust from the air conditioner was blowing over the fin and over the top of the air conditioner vent. Knowing how the refrigerator works with all the updraft airflow and eddys, etc. it seemed like the overflow was blocking the air from exiting the refrigerator vent. That made sense since there was the diverter fin there between the two.
So at International I looked at the different years of trailers. Ours, 1992, had a short little fin. The newer models had TALLER fins than ours. I also checked with an Airstream service fellow and he confirmed that my deduction could very well be the problem. However during the rest of the trip we did not use the air so I could not verify it.
When I got home, I took off our old fin and got a new one. Today I finally I got around to putting it on. The first photo shows the old and new fin. The second shows the taller fin installed.
Has anyone else had this problem?
ID:	27028   Click image for larger version
Roger & Roxie Smith (WBCCI#27380 - Air#178)
Visalia, CA (between Fresno & Bakersfield)
1992 25' Excella - Nuestra casa rodante
2003 F-250 6.0 Turbo Diesel Crew Cab
http://www.casarodante.org
caadoptees is online now   Reply With Quote
Old 10-16-2006, 05:57 AM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
good post and good solution!
my trailer, also a 92, has the same fin.
on mine, the fin and fridge exhaust is on the other side of the ac unit. that is the air intake side for the ac. so in my case changing the fin would make little difference.
post back when you get both running to see if it helps the fridge!
john
you call them ferrets, i call them weasels.
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Spacer on exhaust manifold needs replacing. rdm Mechanics Corner - Engines, Transmission & More... 30 11-19-2002 03:14 PM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 06:54 AM
Forums Directory
