Old 05-19-2015, 12:58 PM   #1
1975 Argosy 26
chambersburg , Pennsylvania
Replacing AC Unit
Our 1975 argosy's a.c. Finally gave up . Instead of putting money into a 40 year old unit might want to just replace the whole thing . Where's the best price?
Jimin pa
jimin pa is offline   Reply With Quote
Old 05-19-2015, 04:37 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Try PPL RV Superstore in Houston. Don't know what the bottom line will be with shipping.
Be aware that PPL may not be informed about the necessity of a properly fitted drip pan. You may be better off purchasing the entire package from a dealer that is familiar with Airstream specific requirements.
Don't know how you use your AS, but in my case a heat pump was by far the wisest choice for replacement units.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-19-2015, 05:12 PM   #3
JimGolden's Avatar
1977 31' Excella 500
15k
I'd recommend a 15,000 BTU unit and never look back. You can always cut it back if it's too cold. None of these aluminum trailers are insulated that well and aluminum has a great heat transfer coefficient (which in English means if it's hot on the outside, it will be hot on the inside).
I replaced the 13,500 BTU unit on my 34 footer with a 15,000, and painted the roof white, and it made all the difference in the world. I went with a Carrier AiRV, but they are no longer made. So I guess you are looking at Dometic or Coleman. Both are good.
As for the drip pan....it's not a big deal. You can let it drip down the side of the roof, along the rain gutter channel (well, Avion has one anyway But if you must have the drip tube hookup, be sure to ask.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 05-19-2015, 06:31 PM   #4
1972 27' Overlander
Denver , North Carolina
Ok, the difference is that your Armstrong AC is typically rebuild-able using parts that local AC guys have, you'll drop $900-$1500 on a new Dometic Penguin or similar and when it goes south, you'll buy a new one. Something to consider.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
Replacing shower/bath unit Silver Trout Cabinets, Counter Tops & Furnishings 1 01-14-2013 11:51 AM
Replacing toilet flange unit...help! Rawkergrrrl Sinks, Showers & Toilets 2 08-19-2009 02:16 AM
shopping for a unit to join at unit rallies GoNomad WBCCI Rallies & Events 35 11-30-2006 03:01 PM
Washington Unit LKappenman Link Archive 0 05-22-2002 07:38 AM
