Old 07-30-2015, 02:17 PM   #1
1969 31' Sovereign
Tempe , Arizona
Replacing AC in 69 Sovereign
I am about to replace the AC in a 1969 Sovereign. Originally it had the Armstrong AC with a thermostat. Unfortunately that means I do not have the 14 inch square hole now standard for mounting AC and will need to cut that into the roof. I am looking for any suggestions on how best to cut the hole. I assume I will need to add bracing for the hole and mounting the AC, so suggestions there would be great as well. I'm looking at the non-ducted Coleman 15,000 BTU unit that comes with the heat pump for heat as well since I believe that would also allow me to have a wall thermostat. I welcome suggestions on which AC / Heat unit folks might recommend as well. Thank you
Jim Holway is offline   Reply With Quote
Old 07-30-2015, 03:24 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Jim,
Take look at our Little Girl Refurb thread starting at post #364:
http://www.airforums.com/forums/f185...-50967-26.html
She's a '72, so close to the same vintage as your trailer. I built a frame out of 2x4's cut down to the thickness of the ceiling, and curved to match the ceiling as well. It's held in place between two ribs, and provide the 14 x 14 inch frame for the new roof a/c. Cutting the aluminum isn't hard - all you need are tin snips.
We used the Penguin 2 roof a/c because we wanted a low profile unit.
Chris
Old 07-30-2015, 07:05 PM   #3
1969 31' Sovereign
Tempe , Arizona
Thank you Chris .... this is very helpful for design ideas on adding bracing. Great work on your refurb!
Old 07-30-2015, 07:32 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
When I had to enlarge and square off the hole for a new Fantastic fan I found that an aluminum cutting wheel on a 4 inch angle grinder was much easier than thin snips.
Just mark your pattern with a sharpie and it cuts like butter. It is a little messy on the inside but if you have a helper hold a shop vac right by the grinder as you cut you won't make much of a mess.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 07-31-2015, 12:21 PM   #5
1978 31' Sovereign
Euless , Texas
replacing your armstron ac
I just replaced my Armstrong ac on my '78 AS 31' Sov. My armstrong had A 14" opening so replacement was simplestablished although I did use a couple of 22' above the ceiling plenum front and back. I went with the Coleman Mach 8 model 47024A876 which is a 15,000 btu heat pump with a condenate pump. Make sure you order this model number because all Mach 8's do not come with a condensate pump. The condensate pump is necessary because you can tie it into the AS through the wall condensate drain line. All other Coleman drain the condensate unto roof which then runs down the wall causing mineral staining ruining the bueatiful AS finish. As far as an on the wall thermostate, I was advised by Coleman tech services this should only be used wit a ducted ac so I selected the ceiling control unit which works fine. Overall, I am happy with the new unit, but don't expect it to perform well in the heat of a 100 degree Texas day with no shade although tolerablet running fans. The AS is a heat seeking aluninum can don't you know. If you really want stay cool in 100+ days upgrade to 50 amp service and install a second ac unit, but make sure you stay in parks that don't charge you for electricity.
rbcarbo is offline   Reply With Quote
Old 08-01-2015, 09:08 PM   #6
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
Jim do you have plans for your old Armstrong A/C unit? Iam in need of some parts for the unit on my 69 safari. How can I get in contact? Carl.
tracker is offline   Reply With Quote
Old 08-02-2015, 06:02 PM   #7
1969 31' Sovereign
Tempe , Arizona
Carl ... glad to see if I'll have some parts you need. Send me an email at Holway.jim@gmail.com ... and provide me a number to call you at as well. Once I finish getting the Armstrong unit off I'll have a better idea what I've got and what I was able to get off without damaging the parts. Hopefully I will be able to finish removing the unit on Monday.
sovereign
Replacing toilet for '69 Sovereign? tdoescher 1965-1969 Sovereign 6 12-07-2010 04:58 PM
Replacing back glass on '75 Sovereign rickastream Windows & Screens 13 07-15-2009 01:32 PM
Replacing Carpet in 1986 31' Sovereign: where to put seams? b8sfamily Floor Finishes 6 03-07-2009 05:13 PM
Replacing AC with fan vent - 79 Sovereign 31' runningman Exterior Restoration Forum 3 06-29-2008 05:26 PM
Replacing Water lines in 31' 76 Sovereign 76sovereign Fresh Water Systems 8 02-07-2008 11:47 AM
