Old 07-05-2018, 11:58 AM   #1
philipsinewe's Avatar
2003 30' Classic
Centerville , Ohio
Replacing 2003 AS AC Unit
OK, looking to replace the AC unit on our 2003. Looking for 1 unit, 15K with heat pump. Lots of question to see what the group thinks in regard to what unit to bu and why.
1: Thermostat wiring.
2: Drainage hose and connection
3: nbrand
Phil and Kathy Sinewe
2003 30' Classic W/Hensley Arrow
2014 F-150
Centerville, OH
philipsinewe is offline   Reply With Quote
Old 07-05-2018, 12:32 PM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
1. Which unit do you currently have?
2. Replace with same manufacturer and reuse current wire harness.
3. Connect to existing drain lines.
Dometic owns almost all of the industry and they have decent units.
vintagemotor is offline   Reply With Quote
Old 07-20-2018, 08:28 AM   #3
2005 28' International CCD
1968 24' Tradewind
Alexander , Arkansas
I just had to add the drip cups to my 2005 AC so I had to pull unit if you want to read through my post a couple below yours. Regardless of the unit you go with you will have to pull the old drip pan assembly from the roof and scrape up all the dicor that bonded it to the roof.
1. If you don't have a thermostat now you will have to fish a wire. My 2005 only has the roof controls.
2. Drainage should come off the streetside of the current unit. Find a 1/2' elbow to help make the connection to the current drain hose so it does not get kinked.
3. I would go back with a Dometic low profile unit with heat strips which is probably what you have now.
Endl is offline   Reply With Quote
Replacing fresh water tank 25 ft 2003 Safari B ssopko Plumbing - Systems & Fixtures 0 09-08-2015 01:52 PM
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
2003 Tahoe for 25' 2003 Classic ilittle Tow Vehicles 8 09-29-2009 10:15 AM
shopping for a unit to join at unit rallies GoNomad WBCCI Rallies & Events 35 11-30-2006 03:01 PM
Airsteam Recalls 2000-2003 Land Yacht -- 08/07/2003 jpurdy Our Community 0 08-14-2003 07:19 PM
