Old 11-20-2010, 03:48 PM   #1
1965 22' Safari
Point , NW
Replacement Furnace
I am new to the Airstream world and this forum. Just purchased a 1965 23ft Safari four days ago. I knew it had a bad furnace, International Oil Burner model. I removed the furnace and am looking for a replacement. I am leaning towards a Suburban, however, not sure which model and size I should order. The old heater was mounted on top of a plenum which feeds duct work. The plenum measures 14 inches wide by 23 inches long. The new furnace will need to have a bottom duct to access the plenum and duct work. I have looked at the NT 16S, as well as, the NT20S. I have not been able to determine if they have bottom ducting. I know I will have to do some retrofitting. Anyone have experience with either of these units?
I have read several classifications in the forum and learning quickly. I did not see any posts with this info.
Thanks Stan
Sburg58 is offline   Reply With Quote
Old 11-21-2010, 11:04 AM   #2
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I, too, am interested in other furnace options for my Safari with a similar setup. I am especially interested in a furnace with a low amp draw for extended boondocking. Anyone have the "perfect" heating unit?
Sam
samb is offline   Reply With Quote
Old 11-21-2010, 11:49 AM   #3
Thanks Stan
A 1965 Safari is a 22 foot Airstream.
For the small difference in price, most owners chose the Suburban NT 30.
It's the same size as the smaller units.
Old 11-21-2010, 02:20 PM   #4
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
As Andy mentioned the NT30 SP is the current replacement unit. Best deal:
Palomino RV
1047 E M 86
Colon, MI 49040
269-432-9791
good thread:
http://www.airforums.com/forums/f427...t22-60533.html
Pics:
http://www.airforums.com/forums/f427...t22-60035.html
RichHog is offline   Reply With Quote
Old 11-21-2010, 04:18 PM   #5
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
As RichHog said Palomino parts: 800-297-5830 has excellent prices.
This is how I did my furnace on a 1975 Tradewind. http://www.airforums.com/forums/f427...4sp-47264.html
Another clean install in a 1970 Overlander. http://www.airforums.com/forums/f427...0sp-41537.html
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 11-21-2010, 05:22 PM   #6
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I installed a new Suburban NT 30 last spring in my 65 Safari. It was a pretty easy job. We just got home from a 3 day trip in northern Michigan with temps below freezing each night and highs only 33. The new furnace worked like a charm....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 11-21-2010, 06:07 PM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The customer support at Suburban in Tennessee was very helpful to me when I needed info in replacing the NT-22 in my Trade Wind. You may want to give them a call before you buy a replacement. After talking with them I learned that I would need a 3rd outlet for the NT-30 to work properly in my TW. Since there was not easy way to do that, Mississippi winters aren't that cold, and I wanted to free up the space under the kitchen cabinet I went with a catalytic. When camping with shore power two small electrics keep the chill off.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-21-2010, 06:24 PM   #8
But that does not circulate heat around the holding tank, which is necessary.
Old 11-21-2010, 06:31 PM   #9
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
My PO took the furnace out when doing a total restoration on my Tradewind. Put in two catalytic heaters, one in the bathroom and another in the front. They sure heat up the trailer fast. I also have an electric one with a timer and a remote control so I can have a little heat when I am going to bed or click it on when I wake up. Keeps things covered if I run out of propane.
cclarkego is offline   Reply With Quote
Help, replacement furnace? knjobrien5 Furnaces, Heaters, Fireplaces & Air Conditioning 22 04-18-2018 01:23 PM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 23 11-28-2011 05:28 PM
Furnace replacement...again walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 16 12-22-2004 06:53 AM
Furnace Replacement RiskIt Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-16-2004 01:50 AM
furnace replacement joecj76 Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-18-2004 10:38 AM
