Old 09-17-2014, 02:15 PM   #1
1981 31' Excella II
New Market , Alabama
Replacement for NT30
If I am correct the replacement for an NT30 is the NT30SP. Is this one shorter than the NT30? I have seen folks build boxes to put them on to get the correct height. This would actually be a good thing because then I can get it out after I put some floor covering in. Right now it is bolted directly to the floor. It is under the stove/oven. I would like to run another duct to the back of the trailer as well. There is one duct back there but the flow is not great due to the distance. The front of the trailer gets much hotter than the bedroom at the back. I am not sure I can get another tube back behind the bathroom.
Perry
Old 09-21-2014, 07:45 PM   #2
1981 31' Excella II
Just for reference. The NT30SP which is a newer version of my 1981 vintage NT30M is an exact replacement. It went in with very little changes. The left vent which discharges into the living area was a little higher but I reversed the junction box for the vent and it fit perfect. Overall length and width are the same and the height of the intake and exhaust vents are the same.
Perry
Old 09-21-2014, 07:47 PM   #3
Perry
Correct.
Old 09-21-2014, 08:25 PM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Perry I'm in the market for a new NT30SP. Did you purchase your NT30SP online? Thanks!
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 09-21-2014, 08:30 PM   #5
Indiana, PA
TAC PA-5
WBCCI 4871
Bob.
We learned the hard way, that Suburban does not pack those furnaces very well, resulting in damage.
Have one drop shipped to you from as close a source as you can.
Or, pick it up.
Old 10-27-2014, 11:03 PM   #6
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
We got our NT30 SP drop shipped from Suburban bought it from Vintage Trailer Supply.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 10-28-2014, 04:45 AM   #7
1981 31' Excella II
I was able to buy my furnace cheap from an RV salvage place here in Alabama that had some new old stock. The stuff is a little musty but the price was right. Andy is correct about the sheet metal being easily damaged. It is much thinner and softer than the old units. It was almost as bad as tin foil.
Perry
Replacement for a Suburban NT30-K furnace? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 16 04-25-2015 08:09 AM
nt30 in nt22 case???? Raymond Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-18-2009 08:37 AM
New Suburban NT30 Question on Brass Elbow kneal Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-23-2007 06:37 AM
NT30 M - or NT30 SP? bsherman Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-29-2006 05:44 PM
NT30 Suburban, slight problem Pick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-26-2003 07:16 PM
