Old 10-24-2006, 09:42 AM   #1
Mont Vernon , New Hampshire
Replacement for DuoTherm Heater?
Hello all,
We need to replace one of the Duo Therm Furnaces in our 1986 345 Motorhome.
Has anyone done this? What would be a good replacement for this furnace?
It is Model 901 30-001
Thanks for your help!!!
bugsbunny is online now   Reply With Quote
Old 10-29-2006, 12:20 PM   #2
Classic 325 MH
Eddy's Avatar
1985 32.5' Airstream 325
Rochester , New Hampshire
Originally Posted by bugsbunny
Hello all,
Hello Bugsbunny!
We don't have any idea, but look forward to hearing the suggestions since we may need to know one day ourselves.
Hope all is well with you and that this is a fairly easy fix.
Jeff & Kristine
Classic 1985 325 Motor Home
New England Unit
WBCCI # 5971
Eddy is offline   Reply With Quote
Old 10-29-2006, 03:57 PM   #3
1985 34.5' Airstream 345
Fishers , Indiana
We also have a '86 345. I replaced the furnace in the front under the sink with a new unit that is installed / serviced from the outside. I can provide model information and pictures of the install. It sounds harder to do than it turned out to be. I spent about 4 hours installing the new furnace and it looks like it came from the factory. I had taken the old one to the Airstream plant in OH which was a big waist of time. They charged a couple hundred dollars to tell me they could not fix it since they do not have the parts (it needed a new fan motor). We are still using the original furnace in the rear bedroom and it works like new once taken out and cleaned.
Wayne Olson is offline   Reply With Quote
Old 10-29-2006, 05:48 PM   #4
str8strm's Avatar
Tujunga , California
Hi Wayne, both of ours worked fine 6 months ago, now all they do is blow cold air what is the model number?
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 10-29-2006, 06:03 PM   #5
Hi Wayne,
Pictures and model number would be great. The one that has failed is the same as yours - Up front under the sink area.
Thanks!
Old 10-30-2006, 03:50 PM   #6
Fishers , Indiana
Front Heater Replacement
I replaced the front heater on our 345 with an Atwood 8500 series heater available from any RV dealer or Camping World. See the attached pictures for more detail.
Name:	AS345frontheater outside view.jpg
ID:	27751   Click image for larger version
ID:	27753   Click image for larger version
Old 12-15-2006, 09:32 PM   #7
furnace is actually working!
In August our front furnce would not lite and we found critter nests in the exit port. After cleaning the exit out, it still would not lite and so we broke out the little portable electric heater for the front and ran the back furnace.
Our propane monitor indicated that the tank was full.
When we got home, we took the furnace out a few times and eventually decided that we would try to replace it. Well, it turns out that these furnaces aren't made any longer so we said we'll look around during the winter and try to find a suitable replacement.
Meanwhile, I read somewhere (either here or in the Airstream manual) that the front furnace will not actuate heating when the propane is too low - in order to keep the occupants sleeping in the rear warm while sleeping.
So we talked it over and noted that we had acutally ran the propane quite a bit during the cool spring trip to the beach and our 5500 camping trip this summer and the 7 rallies we had been to and that a 3/4 full reading might be an incorrect indication of the propane level.
We decided to fill the propane just before putting the baby up for the winter last weekend. When we returned, my husband decide to "give it a shot and low and behold it worked! Yippee!!! The manual was right!!!
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water Heater Replacement rpwx Water Heaters, Filters & Pumps 2 04-23-2014 01:43 PM
heater... Basotrol replacement? help Tick Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-07-2005 02:45 PM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 03:53 PM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
