Old 04-24-2015, 12:49 PM   #15
It would be helpful to some forum members, including me, if you would be kind enough to detail the replacement model furnace, and any tips you might have on the conversion. Thank you in anticipation.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-25-2015, 07:24 AM   #16
coloradopete
coloradopete's Avatar
1988 25' Excella
Montrose , Colorado
NT30-K Furnace replacement
My trailer is the 1988 Airstream 25' Excella.
I have just completed the replacement of the NT30-K with the Suburban NT30-SP. The new model fit into the space of the old version very nicely. I did need to enlarge the opening in the inner wall for the furnace housing and cut two holes in the outer skin of the trailer for the intake/exhaust pipes. On the outside, I left the 2 holes (on the right) of the old unit covered with the old plate, for appearance, after plugging those holes. With the furnace in place, I then located the points for the 2 new holes and found that the location of the third hole of the old unit (on the left) was mis-aligned. I used a piece of 1/8" thick aluminum sheet, 6" x 8", to cover that hole, then cut the 2 holes for the new unit. Tools used: Small Dremel hand tool; hand drill; hand held jig saw with fine tooth blade. Used plumber's putty for the exhaust cover plates.
As the propane gas outlet is located on the opposite side of the new furnace, I used a piece of hose (made for propane) to make that connection. The hose is 22" long which assures it will not touch any part of the hot furnace housing. Be sure to test all new gas connections for leaks!
I also had to trim the wood cabinetry a little to permit the heat duct tubes to connect to the furnace duct outlets without undue stress. This is to the right of the furnace, inside that compartment.
I am favorably impressed with the performance of the new furnace: quiet, lots of heat, and starts quickly. I urge you to read the installation instructions very carefully and follow them to the letter!
ID:	237020   Click image for larger version
ID:	237022   Click image for larger version
coloradopete is offline   Reply With Quote
Old 04-25-2015, 08:09 AM   #17
Very useful and complete information, thank you. I have the same year and model trailer, and expect any year soon to have to make this replacement.
Nick.
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 23 11-28-2011 05:28 PM
Where's the best deal on a Suburban NT30? RichHog Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-25-2010 01:43 PM
Replacement thermostat for Suburban furnace SafeHarbor Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-09-2005 10:14 PM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2003 01:53 PM
NT30 Suburban, slight problem Pick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-26-2003 07:16 PM
