Old 06-21-2009, 11:08 AM   #1
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
Replacement Fan Motor for Roof Exhaust Fan
Hi all. My roof exhaust fan motor seems to have stopped working in my 74 31" Sovereign. I am looking for a replacement motor as I can't afford to put in a Fantastic right now as I would like to. Anyone have a source for it?
Thanks, Richard
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Old 06-21-2009, 12:13 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Richard!
Thanks, Richard
Inland RV lists a ceiling vent fan motor on their website sale page. See Ceiling Vent Fan.
I have purchased a number of parts for both my Overlander and Minuet from them and all have been of the best quality and fit with few if any headaches.
Kevin
Kevin D. Allen
AIR #827
Old 06-21-2009, 12:38 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you're lucky, you can find someone who is installing a fantastic fan. I was able to get a motor for the cost of shipping.
Richard
Old 06-21-2009, 12:48 PM   #4
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
We got new motors for them from Inland RV. They run about $57, plus shipping of course. We still have one left to install, so I can get the model/part # off our new one for you if you want to do a search for someone local who might have them. That way you won't have to pay shipping. Someone else must stock them. Inland has to get their supply from someone (manufacturer). I will post a photo and detailed model number off it later today. Now if you need a new fan blade and plastic shroud for around it, that's a AS specific part and I know that Inland has those too. We bought some of the also, as we were adding a fan where there wasn't one. The blade runs approx. $9, and the shroud $14 if I recall. So for well under $100, even if you added shipping costs you could have a whole new setup, without having to modify for a fantastic fan.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 06-21-2009, 01:21 PM   #5
SaabLover's Avatar
Images: 12
Mary
Everything else is fine just need motor. Motor still works if I pull on wires but then goes off again. I am afraid it might catch fire or something. 35years old and all.
Old 06-21-2009, 04:35 PM   #6
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Sounds like the flexing over the years has broken the copper wire inside the insulation. How good are you with a soldering iron? Remove the motor, take it apart, replace the wires & you should get away dirt cheap.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 06-21-2009, 04:43 PM   #7
SaabLover's Avatar
Images: 12
Ricky
Certainly worth a try anyway. Thanks
Old 06-21-2009, 06:17 PM   #8
Tinsel Loaf's Avatar
I would take the old motor apart and repair the broken wire, clean the bearings (most likely sleeve) and motor shafts. Lube the bearings with a light oil. Mark the motor when you open it so you put it back together the same way it came apart.
Tinsel Loaf is offline   Reply With Quote
Old 06-21-2009, 06:27 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Be careful with the fan blade. It can break easily (don't ask), but replacement blades are still available.
Richard
Old 06-21-2009, 07:09 PM   #10
SaabLover's Avatar
Images: 12
Yes I am sure that the plastic is quite brittle. Not unlike the peanut brittle. Just like most of the other plastic in the Sovereign.
Old 06-23-2009, 07:49 PM   #11
Liberator
klattu's Avatar
1972 Argosy 24
Heart of Dixie , Alabama
Images: 834
I also wanted the fantastic-fan, as they looked like they could move some air.
But they don't give them away free anymore.
So after you repair your wiring, maybe make up a set of extra large blades.
With these on, I can now feel a breeze from an open window.
Heres the parts needed
Find center, mark it well, and scribe radius.
About 10" maximum
Lay out blades
I made 15
Cut outside.
And sand edges now, before you cut blades
First bends made to blades.
It would work here, but I wanted more
My version of Tornado-Fan
Most important...the center hub.
Trick here is to place bolt in drill press chuck, and the drill in a vise below.
That way it will find true center.
(poor man's lathe)
Old 6" vs new 10"
What a change!
Now it really moves some air...and looks Airstreamy...not SOB plastic
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 06-23-2009, 08:23 PM   #12
Maryw164's Avatar
1972 31' Sovereign
If you are using the original shroud with it then a 10" blade will be too big. Maybe that's why yours didn't move much air, if you didn't have the shroud on it. I think it's designed to work best with the shroud.
Mary
Happy Trailering !
Old 06-23-2009, 08:28 PM   #13
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Shroud?
What shroud?
Click To See Me Wet
1972 Argosy 24'...
Old 06-23-2009, 08:41 PM   #14
Central , Mississippi
Ricky
There's also a chance the brushes are worn out or hung.
Mine suffers from armature hang. The darn thing works great on the bench, mounted verticle it drags, probably needs a spacer adjustment. I believe Terry went thru the same issue with his AC unit on his fulltimer thread.
I tend to use the other roof fan...15,000 BTU....
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
kitchen exhaust fan repair/replacement??? charlie tuna Roof Vents, Skylights & Fans 17 12-12-2016 05:20 PM
Exhaust fan motor Dr Dan Roof Vents, Skylights & Fans 7 10-08-2008 11:25 AM
bathroom exhaust fan handle replacement charlie tuna Roof Vents, Skylights & Fans 8 09-08-2006 06:40 PM
Coleman AC fan motor replacement paddy79 Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-26-2004 09:16 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
