Old 06-23-2009, 09:44 PM   #15
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
This Shroud:
Here's a pic of the old one we replaced. It mounts up in the opening before you permanently attach the motor and blade.
Mary
Name:	old fan and shroud.jpg
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 06-24-2009, 09:42 AM   #16
Originally Posted by klattu View Post
I also wanted the fantastic-fan, as they looked like they could move some air.
But they don't give them away free anymore.
So after you repair your wiring, maybe make up a set of extra large blades.
With these on, I can now feel a breeze from an open window.
Heres the parts needed
Find center, mark it well, and scribe radius.
About 10" maximum
Lay out blades
I made 15
Cut outside.
And sand edges now, before you cut blades
First bends made to blades.
It would work here, but I wanted more
My version of Tornado-Fan
Most important...the center hub.
Trick here is to place bolt in drill press chuck, and the drill in a vise below.
That way it will find true center.
(poor man's lathe)
Old 6" vs new 10"
What a change!
Now it really moves some air...and looks Airstreamy...not SOB plastic
klattu,
Is your custom fan blade any noisier than the original smaller blade?
By the way, that was an ingenious idea!
bkahler is online now   Reply With Quote
Old 06-24-2009, 10:37 AM   #17
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
It does make a different sound.
I can tell it spins slower.
Makes a lower pitched sound, and is more as a house fan sound.
My original 6", I never had a shroud
The 15 blade 10"
And this is a 9 blade 10"...i think this one flows more air
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 06-24-2009, 07:32 PM   #18
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Notice on the 6" fan, I do have the screens, just not installed at time of blade change.
I wanted to replace the gasket while I'm doing all this.
Yes, it moves much more air.
If the window is opened about 5", there is a breeze coming thru.
No, there are no shrouds, but now they are not needed.
And I added to check for corrosion between the S/S bolt and aluminum blades every 20 years.
Click To See Me Wet
1972 Argosy 24'...
Old 06-25-2009, 05:46 AM   #19
Klattu,
The only issue I can think of that you might affect you down the road is the larger fan blades probably draw more current which will shorten the life of the fan motor.
Then again the larger amount of cooling air passing the motor might keep it cooler so it could last longer.......
Keep us posted on how they hold up over time.
Old 05-15-2010, 10:38 AM   #20
Hack
1981 25' Excella II
Mesa , Arizona
I have a NOS replacement fan motor
Hi.
I have one of these. The Airstream part number is 510228-100. It is still in the box. It was made by DCM. Let me know if you'd like it. I'll sell it for $50.00 shipped to your door.
karisk12 is offline   Reply With Quote
Old 01-08-2014, 04:00 PM   #21
1975 25' Tradewind
VA Beach , Virginia
Wink ebay motor
I had bad front fan motor and replaced it with $17.00 12 V fan motor off ebay and new fan blades available too .
not as big as original But it mounted the same and works fine.
jimrich60 is offline   Reply With Quote
kitchen exhaust fan repair/replacement??? charlie tuna Roof Vents, Skylights & Fans 17 12-12-2016 05:20 PM
Exhaust fan motor Dr Dan Roof Vents, Skylights & Fans 7 10-08-2008 11:25 AM
bathroom exhaust fan handle replacement charlie tuna Roof Vents, Skylights & Fans 8 09-08-2006 06:40 PM
Coleman AC fan motor replacement paddy79 Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-26-2004 09:16 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
