Old 06-05-2009, 12:24 PM   #15
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
Question
We replaced the air conn thermostat and it works great.....I hooked it up then we replaced the fridge. Jack had to remove it and after hooking it back up to the thermostat it has a black wire that is going to nothing....I had folded up the wires we were NOT using (it was for heat and air so there were extra wires) so I could recognize the ones we didn't need.
The black wire was not folded but is not hooked up. Does the black wire hook to something or did I forget to fold it?
We used the air this past weekend and it works it never shut down thou...
Thank you in advance for your help
Kani
76sovereign is offline   Reply With Quote
Old 06-26-2009, 09:09 AM   #16
Dr.Theopolis's Avatar
1977 24' Argosy 24
St. Augustine , Florida
Originally Posted by MaxAB View Post
Is there any A/C units out there that can start up and run off a single Companion?
I just installed a Polar Cub 9000 btu unit in my 24-ft Argosy and so far it runs great on one Honda eu2000i. It evens run fine with eco throttle which is great because if I set the thermostat something less than full cold, then the unit can cycle off and on during the night (and not freeze me to death) and I can keep the generator on eco throttle. Of course, on days in the 90's with no shade, 9000 btu is not adequate but my priority was to run something off the one generator.
The installation manuals says "IF your unit came with a drain tube..." well I guess mine didn't. I haven't found it yet anyway. So water drip drip drips all over the outside of one side of the motorhome.
Dr.Theopolis is offline   Reply With Quote
Air Conditioner Replacement John Sims Furnaces, Heaters, Fireplaces & Air Conditioning 26 10-10-2015 02:20 PM
Air Conditioner replacement for 78 Safari bacevedo Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-24-2008 11:52 PM
AIR Tank replacement clmommens Hitches, Couplers & Balls 4 04-23-2008 08:38 PM
89 354LE air bag replacement swinginping Classic Motorhomes 16 04-15-2008 09:09 PM
Replacement Air Conditioner for 71 Tradewind Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-01-2007 06:32 AM
