Old 09-16-2010, 10:20 AM   #1
1983 31' Excella
Tieton , Washington
Replace Water heater regulator
On our first trip out I discovered that our water heater regulator does not close completely. After it shut off it still had a decent sized flame that would continue to burn. It would appear that it has a lot of oxidation on it, as the AS was parked on a island near salt water for a year. Is it possible to replace just the regulator or do I need to buy a complete heating system. I believe the system is pretty new as it had a new exterior white cover inside the AS. But they left the old cover in place for obvious reasons.
vvolf27 is offline   Reply With Quote
water/moisture in h/w heater regulator Cochese LP Gas, Piping, Tanks & Regulators 0 08-23-2010 07:28 PM
Regulator Low Pressure / Water Heater Burner 77Overlander LP Gas, Piping, Tanks & Regulators 1 10-26-2009 03:28 PM
Need regulator for Bowen G-110T hot water heater SJ1 Water Heaters, Filters & Pumps 5 04-20-2008 07:42 PM
Water heater - keep it or replace??? Bryanhu Water Heaters, Filters & Pumps 29 10-23-2005 12:40 PM
Need to replace water heater... Hotlead Water Heaters, Filters & Pumps 10 05-28-2005 11:04 PM
