Old 02-10-2007, 12:48 PM   #1
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Replace heater duct with flex hose?
Greetings, fellow forum members!
In a continuing effort to get my new furnace installed in my Excella, I've decided to remove the restrictive standard ducting and replace it with aircraft CAT or CEET flexible duct tubing.
I plan to have one line supplying the bathroom and the two under-shower-pan 2" lines to the holding tanks. The other one will run back to the bedroom, and the third one to the front of the trailer.
I could use two 4" Y-adapters and two 4" to 2" reducing adapters to do this, but I'm not finding the parts readily available on the web. Does anyone have any leads as to a good place to look?
To explain better, it would have to be a Y-adapter connected to a Y-adapter with the most straight through path continuing to the bathroom vent (which will be a 4" vent itself). The two reducers would then go on the other two open tubes on the Ys.
Or does anybody have any idea how it can be done more neatly?
I've done some extensive Googling around and even tried Aircraft Spruce & Specialty. It's always fun when you have an IDEA about how to something but have trouble finding the parts!
Thanks!
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 02-11-2007, 01:35 AM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I dunno. How's that for some quality advice?
I would check in with a Heating/Air Conditioning shop. They use a lot of the flexable ductwork, they also do sheetmetal work and may be able to fabricate the Y you need if it's not otherwise available.
Just a thought...
Dave
Fyrzowt is offline   Reply With Quote
Old 02-11-2007, 07:07 AM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I guess you didn't understand how I explained it, I'll dig up a picture, you don't need the reducers.
Hold off till I get you the pic's or I'll PM you my tel#
This is a 2 minute job.
'77 Sovereign Intl 31' CB
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
