Old 03-13-2016, 12:20 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Replace CCC 4 button buttons
I replaced the buttons on our 4 button thermostat. It actually works!
Bride can now easily control the AC, furnace, fan speeds, etc...
Peace and Blessings..
Channing
WBCCI# 30676
Old 03-13-2016, 05:39 PM   #2
1998 30' Excella 1000
Livingston , Texas
Mine are getting a bit finicky too. Could you post the part number and where you got the switches. Thanks--
Siegmann is offline   Reply With Quote
Old 03-13-2016, 08:39 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I will try to post. You may have to turn your head to see it
Channing
WBCCI# 30676
Old 03-13-2016, 08:42 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here's the address
Channing
WBCCI# 30676
Old 03-13-2016, 09:08 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Pay attention to how the switches align in front. Now, with a pencil iron, set to about 750 degrees, and the solder side up, put some pressure with your finger on the switch from the other side to provide force so you can "tip" the switch as the solder releases. Now, apply soldering iron to alternating pins of the switch from solder side. Get the solder to "wet" with pressure then go to other pin.. One side of the switch at a time, not all 4!!! The first one took 5 minutes... By the fourth it took about a minute.
Now, clean the solder holes. First use "solder sucker" to pull out the solder or use pencil iron to move the solder away from hole. Running a steel wire... A toothpick....whatever will help pull the solder clear... Don't ream out the holes as they will help the new ones stay in place as you solder.
Properly align the new switches.. Press into hole until switch bottoms on the circuit board. If it is resistant, verify you align switch with the pattern traced on the board. Don't flex the board.
Once all are bottomed on the board, flip over and solder in place.. A hot iron like mentioned here will solder quicker.. A tip.. Have a small drop of solder on the iron and touch the pin and then when it starts to "wick", drag solder to the board.
I usually let it cool if having trouble with the solder.. Localized heat is what is preferred and a good, hot iron with good heat transfer (solder ball on iron tip), you will not melt the wrong thing.
Channing
WBCCI# 30676
Old 03-13-2016, 09:20 PM   #6
Livingston , Texas
I hear that these thermostats are no longer available and replacement with the newer one is no simple task. A helpful post. Thanks--
Old 03-13-2016, 09:36 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Lewster can get you the kit to update to 5 button... If I couldn't fix this, I was in real trouble....
Today my Bride made me a Pecan Pie!!! Guess I am okay... ? Mmmmmm maybe..
Channing
WBCCI# 30676
Ceiling buttons badkat General Interior Topics 0 10-25-2014 04:48 PM
How are the upholstery buttons installed? m.hony Upholstery, Blinds, Walls & Interior Finishes 4 11-17-2012 06:45 AM
Dometic CCC 2 Thermostat (12 button style) Terratravels 2009-2015 Flying Cloud 12 10-22-2012 06:53 AM
Where can I get these early 60's curtain buttons? RichardT Upholstery, Blinds, Walls & Interior Finishes 15 05-22-2006 10:20 PM
