Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Prev Previous Post   Next Post Next
Old 07-02-2009, 07:32 AM   #1
Profile:  1986 34' Limited
Delano , Minnesota
Replace a NT24 with a NT30 Okay?
New furnace time for me. My old rear bedroom furnace is a Suburban NT24 and I wonder if it is okay to use the NT30? The NT30 may be more common as a replacement furnace. But I wonder if the larger furnace will give rapid heat cycles instead of even heat. My front furnace provides about a 5 degree difference between ceiling and floor, and about a 5 degree difference between off and on. Not the most comfortable thing. Outside temp was about 25 degrees.
Anyway, is it okay to install a larger rear furnace?
David
nt30 in nt22 case???? Raymond Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-18-2009 09:37 AM
7.00-15....what would you replace them with? aircooled4 Tires 12 09-30-2008 05:28 PM
New Suburban NT30 Question on Brass Elbow kneal Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-23-2007 07:37 AM
NT30 M - or NT30 SP? bsherman Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-29-2006 06:44 PM
NT30 Suburban, slight problem Pick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-26-2003 08:16 PM
