Old 04-20-2017, 04:55 PM   #15
timdude's Avatar
Louisville , Kentucky
It's a Delta unit the leak was coming from underneath the wall into the main hallway. It was intermittent so I don't think it was the drain. Bad part is their is no access from behind the wall.
timdude is offline   Reply With Quote
Old 04-20-2017, 08:57 PM   #16
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
I bought a new one and it could not cool the trailer, took hours to bring the temp down just a little bit, old original one worked way better! Just as loud as the old one too.. It's junk to me
bibbs is offline   Reply With Quote
Old 04-20-2017, 10:10 PM   #17
1983 31' Excella
The Woodlands , Texas
I had a old 32 yr old 15BTU Coleman a/c on the front, but it could not keep up with the Texas heat. I rewired to 50 amp and place a 2nd Dometic a/c on the back. I must agree with Bibbs... A noisy sucker :>( Only 3 years of light use and the Dometic lost Freon. I replaced them both. Now I have 2 15BTU Coleman a/c... "I Shell Never Be Hot Again"
Air83 is offline   Reply With Quote
Old 04-24-2017, 08:09 PM   #18
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
bet that dude was R12 and probable low on gas. Mine, a 2005 15K btu is R22 and seems to do a good job after cleaning both indoor and outdoor coils last year. The fins can get so dirty they do not absorb or release heat well during operation.
I have a Bullet Piercing Valve I was going to add to check Freon pressures when it finally get warm around here and not raining..
anyone know the Delta T across the coil.. in home systems its 20 more or less across the coil.
guess Coleman might be the go to for replacements.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-25-2017, 06:14 AM   #19
lewster's Avatar
Naples, FL , Hood River, OR
18-22F but be really careful with this piercing valves. They are only meant for temporary use to drain a system before working on it...to be replaced by permanent Schrader valves later and quickly become a leak source if left in place
Old 08-21-2017, 02:55 PM   #20
2017 23' Flying Cloud
Bartlett , Tennessee
I picked up my new Airstream on 6/2/17. Due to surgeries, we could not take her out until about 3 weeks ago. During that time, we had spent quite a bit of time in the trailer getting it configured to our satisfaction, with the A/C cooling.
About 3 weeks ago, we planned a trip. The day before we were to leave, we turned on the A/C and proceeded to load our groceries and clothes. We noticed that the A/C was not blowing cool air. We cancelled the trip.
We took it to our dealer, who FINALLY, after 10 days, took a look at it. He now has a new A/C on order. The Dometic A/C is being replaced and we have not even had the trailer out ONE TIME!
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 09-06-2017, 03:41 PM   #21
Schwenksville , Arizona
Originally Posted by California27 View Post
I own 3 Airstreams. I have experienced a lot of Dometic A/C failure. I am currently on my 3rd A/C on my 2014 27" Airstream International. The first one failed within a year. Dometic replaced it. The second one failed within 4 months. Dometic replaced it, but made me pay for the dealership labor. I feel this is just wrong.
There are 2 A/Cs on my 2015 30" Airstream International Serenity. I purchased this Airstream 11 months after the original owner purchased it from the dealership. The 13,000BTU A/C in the bedroom failed 2 weeks after I purchased the Airstream. Dometic replaced it at the Airstream dealer. Now the 15,000 BTU unit at the front of the Airstream has failed. The Airstream is still under factory warranty. However, Dometic is refusing to replace this A/C. They say it is because I am not the original owner, regardless of the fact that the Airstream warranty is still in effect. I feel this is just wrong.
Has anyone else had trouble with Dometic Air conditioners failing and further trouble getting Dometic to stand behind their product?
Yes we are dealing with it now. Colonial replaced the rear and both worked on our latest trip, the front does not work now.We have a 30' International Serenity,
Very frustrating especially when it's Hot..
ldhirsch is offline   Reply With Quote
Old 09-06-2017, 03:53 PM   #22
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I just installed a late August build 15k PII.
I'm noticing it doesn't seem to cool anything like my 27 year old Penguin I.
Beginning to think something is wrong. The compressor runs always, and never cycles off!
Cold air comes out, but something is different!
Old 09-06-2017, 09:48 PM   #23
AVS
2018 27' International
Chino Hills , California
Speaking of warranties and AC performance, does the installation of the Micro Air Easy Start void the Dometic warranty?
I have one to install, but I'm thinking I should now wait until the warranty runs out. Any thoughts?
AVS is offline   Reply With Quote
Old 09-06-2017, 09:56 PM   #24
camperguy58's Avatar
Folsom , California
Asked the easy start manufacturer and they said it can be installed in such a way that it can be removed for warranty work if needed. They also said it does not effect the functioning of the ac. Now, that's the easy start manufacturer, so the final call is yours.
Pat
In between campers
2017 Honda Ridgeline Black Edition
Folsom, CA
camperguy58 is offline   Reply With Quote
Dometic Cooling Unit Failures wasagachris Refrigerators 7 08-30-2011 05:08 PM
Goodyear Marathon Failures Surman1322 Tires 677 05-03-2011 01:48 AM
Carlisle tire failures bertro Tires 21 12-27-2006 07:59 PM
2 Catastrophic Tire Failures in 1 Day !!!!!!! gklott On The Road... 59 11-25-2006 10:51 AM
Marathon and other side-wall failures acrane Tires 60 08-16-2006 02:32 PM
