Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 05-13-2005, 01:37 PM   #1
campergirl
Profile:  Mechanicsburg , Pennsylvania
Repairing Furnace in an Ambassador
Hi.
Can anyone tell me how difficult it is to remove a furnace for repair in a 29' Land Yacht Ambassador.
thx
campergirl is offline   Reply With Quote
Old 05-13-2005, 02:15 PM   #2
69 Silverback
69 Silverback's Avatar
Profile:  1969 27' Overlander
Firth , Nebraska
So , what year trailer is it? What model furnace?
On my '69 Overlander, it is fairly simple. It has a Suburban NT 22 furnace. Shut off gas supply. Shut off power to it , should be only 12 volt & turn thermostat off. Disconnect the gas at the unit. Remove the vent from the outside. Remove the Front of the furnace by unclasping the latch at the top, pull back towards you and down. Front door comes off. Then there was a screw/bolt in the lower right corner. Remove it and then the inside pulls out from the case. That leaves the case and duct work hooked up. Don't need the case out to repair it.
Good luck, Loren
69 Silverback is offline   Reply With Quote
Old 05-13-2005, 08:04 PM   #3
campergirl
Furnace
Thanks Loren,
I was told you had to rip the entire kitchen out to get to the furnace, didnt make much sense to me. I would think if it wasnt used for many years it may just need a good cleaning.
Peggy
Old 05-14-2005, 12:20 AM   #4
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Hi and welcome
I bought new so I can't give advice on maintaining or restoring old trailers - however you'll find lots of information by using the "search" command. You may even find someone who has your same model and year.
I did recently see a post where a nearly restored trailer burned. If either your water heater or furnace are very old or are in marginal condition, I say replace them so you don't have to worry about carbon monoxide, fire hazard or the appliance crapping out in the middle of a trip. (And new ones have automatic igniters... nothing like shivering in 45 degree weather in your jammies while trying to light the furnace.)
Paula - aka "Tin Lizzie"
Old 05-14-2005, 06:33 AM   #5
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Originally Posted by Peg
Thanks Loren,
Peggy
I took mine out last Fall. ALL the fittings had cracked and needed to be replaced. Go here and click on the small pics of the furnace to see the larger pic, if you'd like to see how mine came out.
http://www.balrgn.com/Airstream/airs...oject_2004.htm
Here is a good site that has manuals online as well.
http://bryantrv.com/docs.html
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
test
