Old 05-16-2013, 06:40 AM   #1
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
Repairing Cracks in AC Cover
While working on the roof replacing our skylights with Maxim skylights we noticed a couple of three inch cracks in the plastic shroud for the air conditioner. Nothing serious yet, but we want to stop this cracking and prevent future leaks. Your suggestions for repairing these cracking and preventing them from getting bigger would be appreciated.
wolverine is offline   Reply With Quote
Old 05-16-2013, 06:49 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I would just replace it. The UV from the sun is hard to get ahead of.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 05-16-2013, 07:17 AM   #3
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
If this is the original shroud it is very susceptible to becoming brittle due to sun exposure. You can stop drill the ends of the cracks and epoxy some small braces on the inside as a temporary fix but the best fix is to replace the shroud. I replaced mine with the Icon aftermarket shroud and have been very pleased. They are on sale, about $100, this week at the following address.
Air Conditioner Shrouds | AC Shrouds | RV Air Conditioner Covers
fltlevel510 is offline   Reply With Quote
Old 05-16-2013, 07:32 AM   #4
withidl's Avatar
2002 31' Classic
Houston , Texas
I've got a crack around one of the attachment screws on mine (2002 ASCL 31') which I'm going to repair with fiberglass on the underside, just haven't gotten around to it yet; so you might pick up a fiberglass repair kit from an auto parts store and try that.
withidl is offline   Reply With Quote
Old 05-16-2013, 08:54 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
If your Penguin shroud uses the small head screws (newer models use a washer-head screw), you might use some stainless steel fender washers between the screw heads and the outside of the shroud to equalize the pressure points and spread the cracking force over a larger area. Works for me.........and my clients!
Old 05-16-2013, 09:34 AM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I've had excellent luck on plastic repair using West Systems G-Flex epoxy. It is specially formulated for plastic. Rough up the back side with 80 grit , paint some epoxy on the surface and lay fiber glass cloth in it. Add a little more G- Flex and work it in with a body filler plastic spatula. Regular epoxy and polyester resins don't seem to work as well as the G- flex on plastic. I fixed the hood on my John Deere lawn tractor after a major break and it has held up well. Any marine supply should have the G-flex. Be cheaper than a new one.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-16-2013, 11:23 AM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I reinforced ours with epoxy and glass cloth behind the blue border, all the way around. Also some cracks in front and top. Been a few years now, holding up pretty well but a new shroud from the link above will be needed before too long.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-16-2013, 12:21 PM   #8
1963 19' Globetrotter
Moline , Illinois
I second the G-Flex from West ; good stuff.
63air is offline   Reply With Quote
Old 05-19-2013, 10:38 AM   #9
krlajwvater's Avatar
2003 30' Classic
mount joy , Pennsylvania
I've got a new shroud for sale from Icon out of Canada that fits the Dometic Penguin Duo Therm AC , I just got it this spring. $75
krlajwvater is offline   Reply With Quote
Old 05-19-2013, 02:44 PM   #10
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
It must be that blue strip Robert????
When I look at your cover it looks to be sitting higher on the air unit than mine, but when I dig up a picture of mine, I guess it is mounted the same.
For $100 bucks from CW, if its cracked now, I don't think its worth the time to chase the problem around the old shroud. (been there -- done that.)
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 05-19-2013, 02:54 PM   #11
jcanavera's Avatar
Fenton , Missouri
Images: 143
Mine shot craps after 3 years of outside storage with cracks starting to radiate from every screw hole. Once pulling it off I didn't realize how brittle overall it had become. The thing to keep in mind is that the Penguin cover sits against some foam baffles that direct air flow through the system. If that thing flies apart when you are on the road (and I've seen my share while on the Interstate), your air conditioner will not function properly until you get a new cover on. Sometimes its better to bite the bullet instead of trying to save the cover, get a new one. All it takes is something to strike it in its brittle state.
Interesting that when talking to Dometic, they only warrant replacement covers for 6 months.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-16-2016, 02:16 PM   #12
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
just when through the same issue with brittle as heck A/C cover. This is a new to us unit, 2005 that has spend winters in FL and for the most part summers in Maine.
I was on roof checking out stuff and seeing how I have a HVAC background was intrested in the AC unit. So I started removing the screws and grabbed the edges to put it of and SNAP a large chunk of the shroud came off in my hands..
I got it off with out breaking off much more and went on line to find a replacement. Got one ordered and it arrived from PPL in 2 days.. $96 with shipping. The foam was crumbling and coming off in my hands.
The new cover a nice polar white was AWESOME.. the old one appeared to be a beigeish look.
The kit came with new foam tape and i replace the old rusting screws with SS ones
While I had the top off I used some nonacid coil cleaner on the condenser coils. the foaming is letting you know the cleaner is doing it job.
I saw the cover for the indoor or evap coil so I proceeded to remove the cover to that.. Now I can see inside the AS. I used a wet dry vacuum to control water or flow and to get water that might overflow to the inside.
that coil foamed up good as well.. it common for these unit to never be serviced along the way.. most of the time the cooling goes down and down till you take it to the local RV dealer who first thing is to replace it.
after getting the system cleaned up I put it all back together and getting ready to hit the road with my "new" 10 yr old system..
stupid photos.. right click to open in in tab to see them..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-16-2016, 02:55 PM   #13
2005 19' Safari
GLENDALE , AZ
We replaced the air conditioner shroud on our 2005 19' Bambi. I leaned on the air conditioner to steady myself while on the roof, and my hand went right through the shroud. We got our replacement on Amazon:
Amazon.com: Dometic Penguin A/C Replacement Shroud fits 11,000 BTU & 13,500 BTU. (This is a replacement for older Penguin models; and it does NOT replace Penguin II low profile models).
Old 04-16-2016, 03:08 PM   #14
dznf0g's Avatar
Oswego , Illinois
Google Icon website. They make covers out of much better material. I've had one for 5 years and it is still like new.
-Rich-
