Old 07-08-2011, 08:17 PM   #1
rayandre's Avatar
1970 27' Overlander
Shaker Heights , Ohio
removing the heater and cabinet from a 70 Overlander
So I'm replacing the original Suburban with an Olympian. The furnace came out easily but the cabinet seems to be stuck. I've removed the ducting from the plenum, removed screws holding the plenum to the floor and I see no mounting screws attached through the exterior to the frame of this cabinet. I can see the two vents and see outside but no rivets or screws. It wiggles a little but something is keeping it from coming out. Any ideas? I'm very close to just taking acutter to it and cutting it out!
rayandre is offline   Reply With Quote
1968 Avion C11 Truck Camper restoration jforb Vintage Kin 310 01-04-2016 06:20 AM
Water heater cabinet cover to 1974 Overlander GeoStreamer Cabinets, Counter Tops & Furnishings 3 05-30-2011 12:35 PM
Water Heater suggestions for '64 Overlander robwok 1960 - 1964 Overlander 4 03-02-2011 07:27 PM
Electrical? Water heater? Water pump? robwok 1960 - 1964 Overlander 6 02-09-2011 11:53 AM
