Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-26-2002, 04:46 PM   #1
Profile:
Removing the Armstrong AC unit
Removing the Armstrong AC unit was a slow task. It takes time to dig out 150 sheetmetal screws. This unit was mounted with lots of screws and more roof caulking. The heat gun softens the caulking enough to remove the coating over the screws. The good old DeWalt drill/driver removed the screws quickly. There are also wires to cut for the t-stat control and the romex wiring for AC power. It was a bit of a chore to slide the unit off the roof on a piece of 1/4 inch plywood down a ladder. The new unit, a Coleman, is a little heavier, so some structual engineering is needed. The span on our '79 Land Yacht 31 ft is 43 inches between ribs. My first thot is to brace above roof line. The interior ceiling is very fragile. The support material will be some 1 inch square tubing with 1/8 inch wall thickness. I just love a good challenge.
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 07-27-2002, 08:48 AM   #2
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Pay attention here folks. Frank always does it right.
Most people and even many repair centers would have just slapped the new unit on without even thinking about a weight difference.
Good luck Frank and keep the pictures coming.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 07-27-2002, 11:34 AM   #3
Profile:
Armstrong AC parts
Free parts to anyone needy. Unit removed from 1979 Airstream
Name:	ac shroud.jpg
Old 07-27-2002, 11:39 AM   #4
Profile:
Wiring Diagram/Drawing AC Unit
Electrical drawing for Armstrong Roof AC unit.....
Name:	ac unit wiring.jpg
Old 07-27-2002, 11:44 AM   #5
Profile:
AC removed view
Roof construction and rib inside view
Name:	inside roofview.jpg
Old 07-27-2002, 12:05 PM   #6
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Frank,
Iwant it! I will pay to get it. Let me know. Mine is about to disintergrate.
Also based on the wiring diagram yous had a heat strip and a wall mounted thermostat? Cool!
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 07-27-2002, 01:04 PM   #7
Dana Kelley's Avatar
Profile:
Armstrong A/C Shroud
We are looking for TR21-12 Shroud. This fits 73 Overlander. Have been quoted $375 from a parts place, but we can't afford that! If anyone has one they would like to sell, resonable, we'd like to buy it.
Dana Kelley
jckelley@flex.net
DSK in TEXAS
Dana Kelley is offline   Reply With Quote
Old 07-27-2002, 02:47 PM   #8
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Smile Selector switch from AC unit
I am looking for an OEM selector switch. mine does not seem to be original equipment.
I am looking for the selector switch that has about 7 or 8 positions on it like High fan, Low fan, high cool , low cool , heat, etc...
This switch is on the left side of the unit facing the control panel.
My switch only has four positions but thew faceplate has many more positions identified on it. I have to put the switch in the "heat" position for it to cool, Hmmm?
Any way I will be happy to pay fro the postage and shipping of the unit.
Ken
smily is offline   Reply With Quote
Old 07-27-2002, 05:32 PM   #9
Profile:
More pics of AC to come
Compressor motor failed all else worked OK......All the components to a good home.....
Old 07-27-2002, 07:51 PM   #10
BobbyW's Avatar
Houston , Texas
Frank;
Before you install the new unit, could you take a few pictures of it without the shroud on it. These would be great reference pictures for the Forums in the future.
Some pictures of the old unit without the shroud would be great also.
-BobbyWright
-BobbyW AIR# 123
-Red Green
Old 08-02-2002, 11:11 AM   #11
montanaandy's Avatar
Profile:
Shroud From 1979 Armstrong AX
Frank:
Just came across this thread re: AC replacement and saw that you have the shroud for the unit available. I have a 79 31' Soverign and I am looking for a new shroud (both top and bottom if possible but esp. the top portion). Is this still available? Thanks, AJ
montanaandy is offline   Reply With Quote
Old 08-02-2002, 12:10 PM   #12
Profile:
AC parts give away
I have tried to send the shroud to a guy in FL. The UPS guy wanted me to build a box for same and support cover so as that other packages would not crush same. I don't want another task. It is free to whomever picks up shroud. This is a fragile part. The part could become trash in shipment. Frank
1971 excella500 armstrong AC Chris Deeley Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-09-2003 04:15 PM
Armstrong AC experience - so far silvercomet Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-03-2003 09:11 AM
Removing a radio/8 track unit for repair or replacement lbf78SvgnInt31 1978 Sovereign 4 07-26-2003 09:19 PM
Armstrong AC available smily Parts Archive 0 07-26-2003 08:39 AM
Armstrong AC unit pics FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 8 08-05-2002 04:26 PM
