Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-21-2008, 10:43 AM   #1
Gambierite
davida's Avatar
Profile:  1979 31' Sovereign
vancouver , BC
Removing rooftop AC unit: how?
Our airstream (79 Sovereign) is permanently setup in british columbia, but it needs a shed roof built on top of it. For a variety of reasons, we'd like the roof to be relatively close to the top of the unit. We never use the AC unit (it just doesn't get that hot =), so we're thinking about removing it.
Is there a thread somewhere on how to do an AC removal and how to patch up the hole?
(we'd move the antenna on the roof).
--david
davida is offline   Reply With Quote
Old 07-21-2008, 11:25 AM   #2
cameront120's Avatar
Profile:  1972 25' Tradewind
Hi David, how are things settling in on Gambier? One thought to consider, if the roof is too close to the top of the trailer, moving the trailer in the future may be very difficult, given grade changes,etc. I suspect that it is really a simple matter of pulling the unit and then framing in the void with aluminum channels to match the thickness of those used originally. Rivet and exterior skin, insulate and add an interior skin. You could re-use the remaining wires for a new light fixture. You could also add a new roof vent at this time. Maybe a Fantastic Fan?
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 07-21-2008, 11:28 AM   #3
Profile:
David, if you put "scaffold" in the search box, and opt for "posts", you will get plenty of information. I chose to build my shed so that the roof just cleared the AC when the trailer was jacked up to take the weight off the suspension. There is also a specific machine like a fork-lift which is used by professionals. However, I see in your avatar that large trees are nearby. I would sling a 6 to 1 tackle from a large bough above the AC, lift the unit a few inches, tow the trailer away, and lower the AC to the ground. The hole would receive an aluminium patch, pop-riveted in position with a bed of Vulkem.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-21-2008, 11:49 AM   #4
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 65
I've removed and replaced 2 units with nothing more than a long sturdy ladder and a rope.
remarkable-ac-transplant
Post No.7 shows the method.
Good luck,
Michael
Click here Airstream Posters & Tee's
by Micheal Joseph Depraida
WBCCI No 8892 | VAC | KC2TQU
ArtStream is offline   Reply With Quote
Old 10-08-2008, 09:03 AM   #5
Profile:  Currently Looking...
turner , Oregon
How to remove Armstrong AC unit
I just got a 69 Interantional that I am taking down to the bones and rebulding. Can anyone tell me if it is possible to remove the Armstrong AC unit without cutting the lines from the topside condenser to the cooling fins inside the trailer? I have the detached the cover piece from the inside cieling; should the complete unit now lift up and out through the top?
mikenason is offline   Reply With Quote
Old 10-15-2008, 07:13 PM   #6
Larry in MO's Avatar
Profile:  1957 22' Flying Cloud
Lone Jack , Missouri
Images: 27
High altitude work for sissies...................
I'm sure Andy and the others are quite right in laying out the steps for safely walking around atop an Airstream. I also am sure that the collective experience of the group will not lead you astray.
One item clearly omitted, however, was the fact that I, for one, do not like ladders or the required 9' of altitude-- 'streamwalking, if you will. In the event there are others out there w/ similar afflictions, I offer the sure-fire system so as not to wet ones pants at altitude.
I've ordered a pair of Fantastic fans and needed a system for installation. I borrowed scaffold stuff from my neighbor who is a steel worker and is still laughing at me.
The "span" is about 8' and he suggested using an aluminum extension ladder that I own and is practically unused even though it is about 10 years old. It has two 12' pieces that I intend to lay across the chasm and use 3/4 plywood as a poor man's walk board after securing all of it together.
I can simply move the trailer fore and aft as I need to work on a different vent. Poor people have poor ways, you know.
Larry
"Turleen", the '57 Flying Cloud
Lone Jack, MO
Pop. 528
ID:	69396   Click image for larger version
Larry
Lone Jack, MO
Pop.528
"You better learn it fast; you better learn it young"-John Fogerty
Larry in MO is offline   Reply With Quote
Old 10-17-2008, 09:35 AM   #7
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
I think the business end of the a/c is all on top, with just the air diffuser inside on your '69, but that was a transition year. If it is a split unit, you're going to have to take it apart to get it off the roof. If it works good now, I would really hesitate to do this (it works, don't mess with it), but can be done. Before starting to take it apart, I would find someone that will put it back together and recharge it first. I'd hate for you to remove it, only to find no one will put it back together and recharge it for you.
(No Longer at Inland RV)
Removing tape from unit searcher Cleaning, Stripping & Polishing 2 05-18-2008 01:27 PM
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 14 07-06-2007 10:16 AM
shopping for a unit to join at unit rallies Spartan WBCCI Rallies & Events 36 11-30-2006 04:01 PM
Removing a radio/8 track unit for repair or replacement lbf78SvgnInt31 1978 Sovereign 4 07-26-2003 09:19 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 12:10 PM
