Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-18-2009, 04:24 PM   #1
WILDRTEXAS's Avatar
Profile:  1970 27' Overlander
ARLINGTON , TEXAS
Send a message via Skype™ to WILDRTEXAS
Removing my 70's furnace...any tips??
Want to take out my 70s furnace. I see 6 screws to the subfloor and the gas line connection. What else is needed to do to remove the furnace? I see 3 furring strips rivited to the interior wall around the furnace is their anything behind them? And ....before I remove it I want to light it to see if it works..HOW??? Serious newbie...be gentle.
Thanks all!
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is online now   Reply With Quote
Old 10-18-2009, 04:49 PM   #2
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
You will also need to disconnect the vent to the exterior wall.
If you are removing it, why light it? At that age, most recommend a service check by a qualified technician. Chances are you would be fine, but BOOM is never a good sound...
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 10-18-2009, 04:52 PM   #3
Fyrzowt's Avatar
Images: 8
Look at post #328 in this thread. Yours very likely is in similar condition.
Dave
AIR #15800
2000 Safari SS 25'
Old 10-18-2009, 05:18 PM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
In addition to the screws which hold the cabinet to the floor. If you take off the front cover you should see 2 screws which hold the furnace works to tracks inside the cabuinet. Take out these screws and the external inlet / outlet cover, gas line , thermostat and 12v lines and the inner works slide out. If the furnace is a NT22 there was a safety recall. Many parts will not be available and it is next to imossible to get anyone to work on these old furnace.. If you are putting in a newwer furnace you might want to save the lower cabinet for ir its ductwork connection.
Pay no attention to the man behind the curtain- WoZ
Removing Suburban Furnace blawson102 LP Gas, Piping, Tanks & Regulators 10 01-29-2008 01:17 PM
Removing Excalibur 8500-III Furnace burobaaje Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-30-2006 10:39 PM
Does anyone have any tips on removing silicone? Petethefeet Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-06-2006 07:40 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
Mid 70's aviontt For Sale & Wanted 0 04-29-2003 07:36 PM
