Old 03-16-2011, 09:17 AM   #1
miscwires's Avatar
1965 22' Safari
Frome , Somerset
Removing International Furnace from 1965 Safari
Hi there
Any ideas on how to remove an International furnace from a 1965 Safari. I dont think it's original but possibly replaced early on - as there seems to be a larger whole cut through the skin - possibly because it was too big to get in. I have removed the electrics, gasline, exterior vent and all the internal rivets I can see/access and would love to be able to remove it from inside so I dont have to remove any exterior rivets. The furnace moves an inch or two but it wont come out.
Do you think I will have to remove this exterior panel?
www.CoolerCamping.co.uk
Camping just got a whole lot Cooler...
Airstreams - VW Campervans - Yurts - Tipis
Where to buy & Where to Rent
miscwires is offline   Reply With Quote
Old 03-16-2011, 09:58 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
You should be able to remove the panel in the trailer, find the connection for gas and electric, disconnect them carefully, and then take out the screws that hold the furnace into the floor. This is provided it is still like the original installation. Should be able to get it out from inside.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-17-2011, 05:10 AM   #3
miscwires's Avatar
1965 22' Safari
Frome , Somerset
Thanks but Ive had another look and it certainly has been installed from the exterior - there's a slight lip all the way around the front face of the furnace which makes it too big to pass through the inner skin. Also the exterior panel has been attached with non standard exterior rivets so will be fairly easy to remove.
Anyone got any tips on cleaning up the grey putty like sealant which I think is called butyl - to get a clean surface for siliconing the panel back.?
1965, 1965 safari, furnace, removal
2006 Airstream 75th Anniversary Safari International TX eBay Watch Airstreams on eBay 0 01-28-2011 08:40 PM
22' 1965 Airstream Safari *ORIGINAL* Great Condition eBay Watch Airstreams on eBay 0 01-27-2011 10:10 AM
1978 23' Safari International info needed ktmmike1 1974 - 1979 Safari 4 01-19-2011 11:07 AM
2006 Airstream 75th Anniversary Safari International TX eBay Watch Airstreams on eBay 0 01-11-2011 10:10 PM
2006 Airstream 75th Anniversary Safari International TX eBay Watch Airstreams on eBay 0 01-02-2011 08:30 PM
