Old 03-30-2014, 02:43 PM   #1
1976 Argosy 26
Houston , Texas
Removing an Armstrong AC
Im removing the Armstrong Ac off my 77 Argosy TT.
I have removed the 60 or so screws and 5 lbs of Vulkem sealent on the roof.
I have also removed the ceiling assembly and its connections but something is still holding it on.
Has anyone experienced the same issue or know what Im overlooking ?
Zach
wzelkins is offline   Reply With Quote
Old 03-30-2014, 03:37 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure of your vintage but most AC units are held down with 4 bolts accessible once the ceiling shroud is removed.
Remove the ceiling shroud and you should see 4 bolts that go up to the unit. Since the AC units were not made for Airstreams they sit on a plastic pan that follows the curve of the roof and presents a flat surface for the AC to sit on.
The hard part is going to be the drain hose. It is in there tight and has very little room to move it off the drain pan. Don't cut it or you will have trouble when replacing the unit
2004 Excursion 4x4
Old 03-30-2014, 08:53 PM   #3
Mixter's Avatar
1976 27' Overlander
Make sure you didnt miss any of the screws. I just did mine, and part was loose, but the other part was sticking. Turned out I missed a couple underneath all that sealant.
Jack it up from the inside, and it should break free. Thing was stuck on pretty good, and super heavy.
Mixter is offline   Reply With Quote
armstrong a/c mike beech Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-06-2007 05:31 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
True story:NEIL ARMSTRONG 53flyingcloud Off Topic Forum 7 11-28-2002 04:50 AM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
Armstrong A/C Woes on 71Sovereign MikeT Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-14-2002 12:09 PM
