Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-27-2007, 02:38 PM   #1
Skye Nomad
Profile:  canmore , Alberta
Red face Removing AC from Bambi ?
Hello, thanks for any advice you can give. My 16-ft Bambi has a big AC unit on the roof. We don't use it. We don't like seeing it. And we'd like to reduce the weight of the trailer. Can it be totally removed and the holes in the roof sealed well enough to keep rain and snow out. I'd also like to get a solar panel up there instead. Maybe could use a couple of the previous holes. Skye
Skye Nomad is offline   Reply With Quote
Old 12-27-2007, 02:49 PM   #2
krikles
krikles's Avatar
Profile:  1965 17' Caravel
west hills , California
I moved my AC and was left with a hole. It was the perfect size for a Fantastic Fan which is really close fitting to the roof. If the hole left by the AC removal is standard size (I think 14x14?) you might want to go that way as it'd be much less expensive than having a new panel put in, is useful, and unobtrusive compared with the AC.
krikles is offline   Reply With Quote
Old 12-27-2007, 06:16 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
You might also consider a MaxxAir fan. I prefer them to the Fantastic Fan because they have an integral cover that vents out the back and sides and can be used in heavy rain without letting any water in!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 12-28-2007, 11:09 PM   #4
Kajtek1
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
Don't they have huge box mounted on the roof?
Something original poster wants to get rid off?
Kajtek1 is offline   Reply With Quote
Old 12-29-2007, 06:58 AM   #5
lewster
Commercial Vendor
lewster's Avatar
You're thinking of the MaxxAir fan cover. The MaxxAir fan is the same height as a Fantastic Fan when closed and no more obtrusive looking. Comes in white or smoke transluscent covers, manual or automatic with remote, thermostat settings and power lid.
The best benefit is that when closed, you don't see it but when open, you can use it in even heavy rain.......something the Fantastics can't do.
I have 2 of them on my 19CCD and with one pulling air in and the other pushing out........I very rarely need air conditioning.
AIR # 10325
Removing paint CTHilmo Cleaning, Stripping & Polishing 2 03-16-2006 11:16 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
CCD International 19 Bambi vs Safari Bambi vajeep 1999 - 2004 Bambi 8 10-02-2003 05:16 PM
removing rivets Tin Hut Ribs, Skins & Rivets 6 08-30-2003 08:34 AM
Removing the shower stall - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 8 06-16-2002 11:35 AM
test
