Old 06-04-2014, 06:09 PM   #1
1969 27' Overlander
St. Louis , Missouri
Removing AC
I have a 69 overlander. The ac, which I'm assuming is original has leaked for years and is very rusty so I'm trying to remove it. I've got all interior parts removed I can, from the inside it looks like roof unit is screwed around perimeter. Not sure how to remove shroud?
Noco is offline   Reply With Quote
Old 06-04-2014, 07:08 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You have to get up on the roof of the trailer (carefully) to get the shroud off by removing the screws from the outside. Once the shroud is off, you'll see how the rest is attached to the roof. We slid ours down a ladder to the ground.
Kay
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 08:34 PM
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 12:56 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
