Old 08-18-2010, 12:47 PM   #15
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Originally Posted by JKnight View Post
I see your from Texas. Do you have any contacts for polishing an Airstream. I just east of Dallas and have had no luck with finding someone.
Thanks, Judd
There is a thread on here titled "$600 polishing job". Here is the contact for the company the guy used. They polish 18-wheeler tanks...
Xtreme Big Rig Mobile & Detailing 308 S Saginaw Blvd 76179, John 817 706 4351.
adwriter73 is offline   Reply With Quote
Old 08-18-2010, 08:29 PM   #16
1971 31' Sovereign
Greenville , Texas
Have you seen them polish AirStreams before? Thats sure sounds cheap.
JKnight is offline   Reply With Quote
Old 08-18-2010, 08:34 PM   #17
1971 31' Sovereign
Greenville , Texas
Basically your saying frame the 14" hole in between the 2 sheets of metal and there is no need to support it back to the supports?
Wondering what kind of wood as well. I have never heard of dried kiln before. I assume thats not something you can get at the local Home Depot?
Old 08-18-2010, 08:36 PM   #18
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
You'll find kiln dried wood everywhere - it's a very standard way of removing moisture to "quick season" the wood. It's still good to let it sit with good ventilation for a while to season nicely before working with it.
TX-16
Dave Park is offline   Reply With Quote
Old 08-18-2010, 08:49 PM   #19
Splitrock's Avatar
Sioux Falls , South Dakota
The opening for my OEM air conditioner was pretty close behind a center rib but the rear rib was about 20" behind the rear of the opening. I built a support frame and slid it all the way back to the rear rib. That way the pads are supported as well as the gasket. After I got the frame installed where I wanted it, I screwed it from below through the inside skin so it wouldn't move.
The wood I used was kiln dried and then air dried to about 8%. I didn't use treated wood because the treatment chemicals are corrosive.
Removing rooftop AC unit: how? davida Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-17-2008 08:35 AM
1971 overlander ac unit durbin Furnaces, Heaters, Fireplaces & Air Conditioning 12 08-08-2008 04:31 PM
Removing tape from unit searcher Cleaning, Stripping & Polishing 2 05-18-2008 12:27 PM
Removing a 1971 Wing Window/ HELP Lumatic Windows & Screens 3 09-13-2007 08:16 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
