Old 02-07-2009, 01:54 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Removing A/C shroud from 1975 Tradewind
I need to remove the Armstrong A/C unit (TR21-12) to repair my roof. Ref: http://www.airforums.com/forums/f427...-in-47634.html
I have read there are 4 screws holding the shroud on, where are they?
I can see 4 screws at each corner of the vent hole where the fan is and there is a strip of metal on top of shroud toward the front just before it angles down with 4 screws in it.
Is this all that's holding the shroud on?
I have taken all those screws out but the shroud will not budge, One of the PO's has caulked the shroud to the roof and I just want to make sure that's all that's holding the shroud on and not some screws I missed.
Camera is broke so I can't post a pic of it.
Your help is much appreciated
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 02-07-2009, 04:08 PM   #2
The 4 screws is all that hold yours in place, unless someone has put Vulkem at the bottom.
Old 02-13-2009, 11:59 PM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Andy thanks for the information. One of the PO's did caulk the shroud to the roof, took about 5 hours to peel all the caulk away but I did save the shroud, it original and in fantastic shape.
Bruce,
My new 1975 Tradewind bmklawt 1970-79 Tradewind 7 11-20-2008 05:05 PM
1975 Tradewind RockGuard latches lovingtahoe Rock Guards, Segment & Window Protectors 7 11-03-2008 12:22 PM
1975 Tradewind 25ft Orion Off Topic Forum 3 03-21-2008 10:26 PM
1975 Tradewind 25' balrgn 1970-79 Tradewind 2 10-23-2004 12:58 AM
1975 Tradewind 25' balrgn 1970-79 Tradewind 0 10-22-2004 12:27 PM
