Originally Posted by dlb435
I checked with a local RV dealer. They use a forklift to get over the trail.
A word of caution: The pan under the AC unit often breaks while changing out the unit. Be ready to stop work and order a new pan.
DITCH THE PAN!!!!!!!!!!
Use Dometic's Auxiliary drain kit and be free of the pan forever!!!!!
It works better too and will not leak condensate into the trailer like a cracked/overfull pan will.
Every other RV manufacturer (and I DO mean EVERY OTHER one) uses this drip kit for their Dometic installations where an internal drain hose is used.
Even Airstream has gone to the drip kit on 2012 and newer units.
