09-01-2011, 05:47 PM
1993 30' Excella
Elora
, Ontario
Remove Air Conditioner to fit in storage?
I have a 1993 30' Excella that I would love to store indoors for the winter. Total height is about 112 inches, whereas the overhead door opening is 108 inches (9 feet). I can easily remove the two fan covers, but what about the air conditioner - is it worth removing it each fall and putting it back on each spring? Or should I look at removing the overhead door and instead putting in swinging barns doors that don't need the extra space for the overhead door hardware? My guess is that option will cost $1k - $2k (I could not do it myself).
Any thoughts?
09-01-2011, 06:12 PM
Wheels Itch)(Must Travel
2014 25' FB Flying Cloud
- east coastal area -
the chances of, and the costs resulting from, screwing up an a/c unit by removing it multiple times far outways the cost of re-doing your garage door.
i would opt for the new 'barn' door.
some people have even removed the overhead [roll-up?] garage door, altered/increased the door frame height and replaced the roll-up door. some doors already have a little wiggle room on overall length and all you need is about 4" extra.
do you have the extra headroom space in the garage?
good luck
az-streamer
Jon & Deb
Phoebe & Ellis - The Airstreaming Mini-Schauzers
[CENTER][I]
09-01-2011, 06:15 PM
1985 34' Limited
1960 24' Tradewind
Summerville
, South Carolina
Our storage place has a similar situation. Permanently solved by permanently removing the AC and putting it inside but that's a whole 'nuther story.
Until the rooftop was removed permanently, we had to make up about 5 inches. I chose to take the wheels off and use two 'skates' to slide the trailer into its spot. The skates were given to me by a friend that works for a trucking company that specializes in moving very heavy and oddly shaped things. Each skate is rated for 10 tons.
You may want to check with a local trucking company or rental place for a pair of similar creatures. Your trailer would only have to ride on the skates for as long as it takes to clear the door.
Another idea might be a set of sacrificial wheels that have no rubber on them that you could change out just to cover the short distance to clear the door. Moving straight back or out on just steel wheels over a smooth, solid surface for such a short distance, done very slowly and carefully wouldn't cause any damage, I wouldn't think.
Just throwing ideas at you. Moving the AC unit on and off would be a lot of work and chances are great that sooner or later you will damage the trailer or the AC unit by doing that repeatedly.
Good luck,
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
09-01-2011, 06:46 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
If it is a standard garage door, and there is enough room above it, the track can be raised and added on to and another panel simply added to the top of the the door. I would have a garage door company come take a look before replacing it.
We have done it a couple times at my work to accomodate larger trucks.
Removing the A/C every year is begging for a leak.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
09-01-2011, 06:55 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
I would look into into removing the wheels to lower the AS.
Modify 4 furniture dolly's would be not very expensive.
Garry
09-01-2011, 07:01 PM
Sioux Falls
, South Dakota
Bi-fold doors
09-01-2011, 08:10 PM
Retired.
, At Large
Why not just let the air out of the tires, back it in, and re-inflate them?
09-01-2011, 09:31 PM
2008 27' Classic FB
Burkburnett
Measure twice, cut once... My overhead door retracts fully above the opening. I must be missing how replacing the doors without significant modification to the door frame would give you an additional 5" clearance. I agree, performing a regular R&R on the A/C unit is asking for trouble. I like the idea of using bare steel wheels, you could probably get by with only a pair. If lucky you might find smaller wheels with the same hole pattern. Are you able to lower your ball height for the maneuver? Assuming you don't have door opener hardware to contend with, will you have enough clearance once inside to jack up the trailer to unload the axles?
AIR 47751
09-02-2011, 07:09 AM
1993 30' Excella
Elora
, Ontario
I can't get any more height with an overhead door - I've had an overhead door company in already to give me ideas, but the trusses are at 10 feet and they need about 6 to 8 inches for the hardware (below the trusses, as they run perpendicular to the door).
Removing wheels and putting on 'skates' is not really an option either - it's gravel up to the shop floor, so it would be really difficult to roll over the gravel to get into the shop. I'm not so keen on driving on flat tires to get it in either, and its debatable whether that will give me the clearance I need.
I'm pretty much convinced that the barn door option is the best thing long-term - no annual putting on / taking off wheels just to store it, simply open the door and go.
@YankeeDoodle - yes, I would have to modify the door frame by removing the 'bulkhead' - about 8 inches that is there simply to frame up the opening for the overhead door. I may widen the whole opening at the same time, as I only have about 3 inches of clearance on either side of the airstream right now - makes for a tight squeeze when backing in!
Thank you for the input - having never removed an a/c unit I'm glad I asked. I don't want to mess around with it if I don't have to.
09-02-2011, 07:41 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Geo,
The gravel and AS ground clearance may prevent this, may be useful to others. Had a similar problem with a friends sob single axle. Backed up as far as we could, replaced the tires/wheels with a smaller wheels from a scrap yard, (w/o tires) backed slowly thru on plywood.
09-02-2011, 08:01 AM
2008 27' Classic FB
Burkburnett
If you're garage will accommodate a larger wider door, in the long run you will be more satisfied and your Airstream will thank you for a roof over it's head. For you it will be a no fuss process each time, just back it in and unhitch. The technical aspects of removing the A/C is not much more than a few bolts and a couple electrical connections... But it's heavy and awkward to handle risking damage to the unit but more likely introducing water leaks in the roof. Go for the barn doors.
AIR 47751
09-02-2011, 08:06 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
can you trench the floor where the tires ride?
Ricky
09-02-2011, 08:16 AM
1993 30' Excella
Elora
, Ontario
Trenching might be an option - cut the concrete then jackhammer out channels for the wheels. I'm concerned that it would have to be very exact though, and if I were to be slightly off when backing in I would rub the sidewalls and potentially damage the tires. And since I have to trench right from the front of the shop I would be concerned about rainwater filling the trenches, then freezing in the winter around the wheels...
09-02-2011, 08:42 AM
Sioux Falls
, South Dakota
Originally Posted by Geobie07
the trusses are at 10 feet.....
The bifold door can open that whole 10'. The top panel sits above the opening. That's the reason they're used.
09-02-2011, 08:56 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
with 3" on either side you won't have far to wander :-)
a 2x4 rail on each side will prevent rubbing on a sharp concrete edge.
you can easily fill the front of the trench with a few bricks and a bit of cement to dam the front of the trench. if the trench is pitched to the front it won't pool anyway.
you only have to trench far enough back to clear the air conditioner and then the wheels would be back up to the regular floor level.
naturally, the easy way is to change the door :-)
Ricky
09-02-2011, 10:37 AM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
........... I only have about 3 inches of clearance on either side of the airstream right now - makes for a tight squeeze when backing in!
3" is VERY tight to back a 30' trailer in. Just a slight angle adjustment will have you against a side. Mine is 12' wide and I can still get into trouble. Go as wide as posible.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
09-06-2011, 02:17 PM
1993 30' Excella
Elora
, Ontario
Follow up if you are interested....
I decided to enlargen the opening to avoid removing the a/c unit each year...I spent several hours over the weekend doing so and successfully removed the overhead door and hardware, the door frame and the 'bulkhead', widening the opening by about a foot in the process. I backed the Airstream in with ease and it fit beautifully.
Now I just need to build the new door! I'm thinking of a sliding door rather than double barn doors...
09-06-2011, 02:50 PM
2000 31' Land Yacht
Central
When I was building garage, I opted for 10 ft ceiling figuring on enough clearance for MH worked until changed to new MH. I could have gained a few inches if I would have used a steel beam and a lot of inches if I did barn sliding doors on exterior track, but the other owner didn't like the look, reg. garage doors were more acceptable. ;-) Hit the same esthetics on energy efficient roofing, only white, light grey is govnmt approved giving a tax break, but tan matched the house.
01-31-2016, 03:23 PM
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
I have a 2015 FC 23D and need about 2" to clear my carport. Two questions:
Can I deflate the tires enough without damaging them to get the 2"?
Can the top of the Dometic AC (cover) be removed and if so is there any free space below the cover?
01-31-2016, 03:32 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Part one;
Probably, move slowly though, deflate just before moving under, and reinflate just after clearing obstruction.
Part two;
Maybe.
You will need to look to find out.
Part two
Brevi tempore!
