Old 09-16-2004, 09:13 AM   #1
Question removal of furnace in 61 overlander
Looking to remove the furnace in my 61 overlander the blower and controls are gone looking to remove rest of the unit to free up space. wondering about location of gas line and any other mounting areas. also do I remove it to the inside or remove the outside?
heavyduty is offline   Reply With Quote
Old 01-11-2005, 09:44 AM   #2
1969 31' Sovereign
Elizabeth , Colorado
Hi,
I'm planning to remove the refrigerator from a 69 Sovereign, have you tried it yet ? Do you have any suggestions on removing it.
Stagecoachbill
stagecoachbill is offline   Reply With Quote
Old 01-11-2005, 03:35 PM   #3
walter1's Avatar
1964 22' Safari
Foresthill , California
Heavyduty,
Not sure about 61 but for my 64 I just replaced the furnace. It removed to the outside. I had to disconnect electrical wires and gas line, then removed 2 screws holding unit to plenum duct mount. From outside I had to remove heat shield then drill out rivets holding large trim cover in place and slide the entire unit out. New Suburban furnace installed from inside and is much easier to deal with. Only 2 round holes in outer skin instead of large 19"x21" opening.
Walter
walter1 is offline   Reply With Quote
Old 01-11-2005, 11:12 PM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
On my 1963 Overlander the furnace also removes to the outside. It leaves a large rectangular opening, much like the opening for a water heater.
Uwe
www.area63productions.com
Old 01-12-2005, 03:50 AM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by stagecoachbill
I'm planning to remove the refrigerator from a 69 Sovereign, have you tried it yet ? Do you have any suggestions on removing it...
The refrigerator in my '67 is bolted to the floor on one side, and affixed to the countertop on both sides at the top. If I wanted to remove it, I would have to remove the oven to gain access to one side of the countertop attachments, and remove the wall partition to gain access to the other attachment.
After removing the nuts holding the refrigerator to the floor mounted studs, the countertop would need to be removed so the refrigerator could clear the studs. I suppose you could remove the studs from underneath the trailer, but have never verified.
Obviously, the gas & power lines would also need to be disconnected. I would suppose you have a very similar arrangement.
Good luck,
Tom
'61 Overlander furnace cover wildcat455 1960 - 1964 Overlander 13 03-03-2009 08:27 PM
Furnace sets off smoke alarm silverback 2002 - 2005 International 37 11-12-2006 08:24 PM
selling furnace '72 Overlander Kae Edwards Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-12-2004 07:37 PM
R & R a Suburban Furnace Janets Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 07:19 PM
Oxidation removal on 63 Overlander jwi1939 Cleaning, Stripping & Polishing 0 03-04-2003 07:15 PM
