Old 12-16-2015, 11:24 AM   #1
Hoyt
1973 23' Safari
Brandon , Vermont
Recommendations on ac replacement
I have 1973 23' Safari . It has original ac unit on it that needs replacing.
So what is the best unit available with heat pump that utilizes interior drain line for airstream. Should I stay with 13.5? Or go to 15? Low profile or not?
I would love some feed back.
Bill
gahaganw is offline   Reply With Quote
Old 12-16-2015, 02:56 PM   #2
1976 31' Sovereign
Oswego , Illinois
As many have stated on forums if ac can be fixed and is Armstrong, better than any ac on market today.
Old 01-26-2016, 11:16 PM   #3
1966 26' Overlander
Houston , Texas
Also looking for recommendations
My girlfriend has a '66 Overlander and the Coleman AC has seen better days. We're assuming that it's not original and we too are wondering what recommendations anyone can make for a quality AC unit. She already has a central heat unit located elsewhere in the trailer and she used this for working 13 week medical contracts, so she needs something that is not just for "weekend use".
Thanks in advance.
bebo94 is offline   Reply With Quote
Old 01-31-2016, 03:50 PM   #4
1972 27' Overlander
I'm looking for the same info. I bought a '72 Loverlander and I'm assuming I probably new a new AC plus I'd love to find something more efficient than the 70's models.
sir_tob is offline   Reply With Quote
Old 01-31-2016, 04:19 PM   #5
AC's
From 1964 until today, all of the air conditioners that Airstream has used, were "top" of the line at that period of time.
The only problem with the older units is the lack of adequate BTU output.
Today, 15,000 BTU units are available.
Back then from 1964 to the 1969 models 10,000 BTU was all that could be had.
Technology, in time, rewards most all of us with improvements and better designs.
Look at most any car today from even 5 or 6 years ago.
Old 01-31-2016, 05:18 PM   #6
1972 27' Overlander
Here are some threads but I love to hear if others have found anything new and more efficient.
http://www.airforums.com/forums/f427...ent-10206.html
http://www.airforums.com/forums/f44/...ll-115745.html
Water Pump replacement recommendations jimmyroy Water Heaters, Filters & Pumps 4 04-24-2013 11:19 AM
Range replacement recommendations? DavidsonOverlander Stoves, Ovens & Microwaves 5 06-05-2010 12:33 AM
Replacement furnace recommendations for '69 Safari? fotochop 1969 - 1973 Safari 2 10-30-2007 08:53 PM
Classic MOHO Replacement Battery recommendations zamboni Classic Motorhomes 10 10-30-2007 07:28 PM
TV Shock replacement recommendations FordTruck Tow Vehicles 15 12-31-2006 01:01 PM
