Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-14-2005, 03:35 PM   #1
LowellN
LowellN's Avatar
Profile:
Recharging A/C
The Armstrong A/C on my 75 Sovereign seems to work well. My only concern is that on a hot humid day, say around 90 degrees, it runs on high constantly to hold the trailer at about 75 degrees. IS this normal or should it do a better job? I know it's a large area, but I think it should be able to cool it off a little better without running non-stop, am I correct? The air is relatively cold but not super cold. It doesn't freeze up at all, so I'm not sure if it's low on freon or not. One more question, has anyone changed the R-12 freaon in their Armstrong to R-134a? I've been told that I can do this by one of my friends who used to work in the refrigeration business, but I'm wondering if anyone else has done this.
Lowell
LowellN is offline   Reply With Quote
Old 06-14-2005, 04:34 PM   #2
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If it's 75 inside and 90 out and if you are in the full sun, I'd consider that your A/C unit is running pretty good. Once you get to a certain point, it's not unusual to find the compressor is running full time.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 06-14-2005, 04:54 PM   #3
till
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
My neighbor (local heating and air guy) says that the Armstrong (1967 version) is a pretty tough unit. But is limited by it's coil sizes. He will help me rebuild mine.
Tedd Ill
AIR#3788, WBCCI#4028 Membership discontinued
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 06-14-2005, 05:27 PM   #4
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
An air conditioner is considered to be doing its job, if it can keep the inside of whatever you are cooling 20 degrees cooler than outside. That would, of course, be plus or minus a couple of degrees, depanding on conditions.
Old 06-14-2005, 07:42 PM   #5
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
pretty sure they use R-22.
john
you call them ferrets, i call them weasels.
Old 06-14-2005, 09:56 PM   #6
early
early's Avatar
Profile:
Just had our '71 armstrong charged. He used R-22. It made a big difference. Live in the south, just about everyday here is hot and humid. It blows nice and cold.
Dawn
early is offline   Reply With Quote
Old 06-15-2005, 01:21 PM   #7
LowellN
LowellN's Avatar
Profile:
Thanks for the information. I'll probably leave it alone unless it starts acting up. If it ain't broke...don't fix it.
Lowell
Old 06-15-2005, 02:31 PM   #8
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Hey, before you all go run out and convert..... I've had some great success with R-12a and R-22a (Duracool). You need no license for it, it's safe for the environment (at least as far as they know now) and it costs and takes less than good ol' R-12 and R-22. We used R-12 a in a walk in cooler that lost it's charge....got plenty cold in there after adding this stuff...and best of all it works under less pressure than typical R-134a and is far, far, far less nasty than R-134a.
Check it out:
http://www.duracool.com/Duracool/refrigerants.html
Old 06-29-2005, 09:34 AM   #9
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Armstrong Recharge Point
I think we need our Armstrong AC recharged (after 39 years!). It didn't really cool down the air in last weeks 90 degree camping trip. The compressor would turn on for a minute or two, then turn off for a couple of minutes and then back on, but no cold air, just a breeze, as if just the vent function were running. Sooo....I'm calling an AC person to come out and recharge it, but...
where does the freon go? Do I remove the plastic cover on the inside and it goes in there? Do I remove the shroud and it goes up top? Inquiring minds want to know before the AC guy arrives.
John
AYRSTRM2 is offline   Reply With Quote
Old 06-29-2005, 09:44 AM   #10
TomW
TomW's Avatar
Normal , Alabama
Images: 77
Originally Posted by AYRSTRM2
...where does the freon go? Do I remove the plastic cover on the inside and it goes in there? Do I remove the shroud and it goes up top? Inquiring minds want to know before the AC guy arrives.
Top side.
Remove the shroud, and the top cover plate. The recharge fitting is where the lines go into a big pile of RV putty. The yellow thing in the picture below is the tip of my ladder; The recharge port is just in front of it.
Tom
Old 06-29-2005, 10:04 AM   #11
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Caution on Armstrongs
I have seen older units that do not actually have a "Charge" port. The line is simply crimped and soldered shut.
In the old days, only AC repair shops would do the work and they would actually solder or install a fitting as needed.
Watch out!
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 06-29-2005, 12:14 PM   #12
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
All Airstream installed Armstrong airtconditioners, had a low pressure charge port.
That was true from 1964 to 1979 models.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-29-2005, 12:37 PM   #13
smily
"Still Working"
smily's Avatar
All?
never say never and never say all............
Respectfully, If I had not seen it with my own eyes, I would not make the comment.
Maybe it was cut off by some novice A/C repairman
Smily
Ken Smillie
Old 06-29-2005, 01:50 PM   #14
AYRSTRM2
AYRSTRM2's Avatar
Armada , Michigan
Thanks, guys. Now if I can just figure out how to get the weird off brand shroud somebody put on up there so I can access the port. Hey, I really appreciate the advice, my wife won't go camping again until we get this fixed!
John
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 03:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 07:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 06:08 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 11:30 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 08:52 PM
test
