Old 08-12-2007, 03:30 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Reburbing an old Suburban NT30MA furnace
Right now I got spark but no flame. Plan on replacing the board for sure. Just don't like the "lock out" on the old board. Is this board (Marksrv.com fan 50 plus page) a direct drop in replacement. Also the furnace always stoped blowing and then would restart the blow for a few short bursts after it go done. I assume this would be the limit switch and I assume the 0230496 would be the replacement for that...
Before I get too crazy on replacement parts is there a way I can test the gas solenoid? Can I just put 12 volts directly across it and see if I can hear it click?
wacnstac is offline   Reply With Quote
Old 08-12-2007, 05:19 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
One thing to check before you put any money into this unit, was it part of the recall. Some older units had the exhaust connection between the heater and the outside duct connected with a rubber bushing. These bushings failed and allowed carbon monoxide to leak into the trailer. Please check this out first. I don't know if they even have a replacement available for them.
The newer heaters have a metal slip connection which is a lot more secure. Newer heaters also take much less current to run the fans 3.5 amps vs. 7 amps. Take a look at them before plunking down cash on an older unit.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-12-2007, 05:28 PM   #3
Images: 43
Mine was not part of the recall and is connected to the outside duct with a metal slip connection. I cannot buy a direct replacement for this furnace or I would.
Now back to refurbing this one....
By the way I check the gas solenoid by putting 12V across it and I get a nice solid click.
Old 08-12-2007, 09:19 PM   #4
Images: 43
Here is a picture of the furnace control board that I want to replace:
Old 08-12-2007, 10:09 PM   #5
Images: 43
Well, I found one problem already. It seems that my limit switch that is supposed to be normally closed is open all the time. That definitely needs replacing and while I'm at it, I want to replace the sail switch, the fan switch, and the main control board (to avoid waking up to a dead battery and no heat due to lockout).
Old 08-13-2007, 09:41 AM   #6
Images: 43
Can anyone tell me if the new Dinosaur Electronics circuit board would be compatible with my furnace and exactly how I utilize it to control the fan? Would I bypass the fan control switch currently on the system?
Old 08-14-2007, 09:26 AM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You might want to try calling these folks - looks like their boards are "universal"... ?
Marksrv.com Suburban RV furnace parts
Suburban Furnace recall !!! NewStreamer Furnaces, Heaters, Fireplaces & Air Conditioning 34 11-26-2015 04:29 PM
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
1973 Furnace Book 74SovereignInt. Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-08-2002 08:59 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 11:54 AM
