Old 05-30-2011, 10:57 AM   #29
Ottawa , ON
Here's the key information from his first post:
"I bought a new rotary compressor that had a bit more capacity (13k vice 11k BTUs) but pulled less current than the old compressor. I also bought a new fan motor. I also decided to make the unit a heat pump instead of just an a/c. So I bought a reversing valve and new bi-directional filter/drier. Since these old units have capillary tubes instead of TXVs (thermal expansion valves), the refrigerant can flow either direction. "
He completely re-built it with more power, less current draw, and also made it into a heat pump!
I am still astounded.
Old 05-30-2011, 06:23 PM   #30
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Very fine work, and thread! Bookmarked. I may never run into one these again. Could have had one for the asking last year, but no trailer and place to store, plus the parts chase dilemma . . . well, I believe I could find a place for it what with all this information.
Plus, a cool custom shroud would sure be a great look on any vintage of aluminum trailer. I like to think that this level of re-building can be extended to the other parts as needed.
Thanks, jmpratt!
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 05-31-2011, 10:08 AM   #31
jmpratt's Avatar
1969 29' Ambassador
Liberty Township , Ohio
Originally Posted by rideair View Post
Jason,
Looking at the pictures, it does not look like the newer style compressor is all that much taller than the old one, if any?
Was it the connections that created the extra height?
The new compressor and tubing is about 6" taller than the old one. If you use a reciprocating compressor vice a rotary, you won't have to modify the cover.
jmpratt is offline   Reply With Quote
Old 05-31-2011, 10:33 AM   #32
rideair's Avatar
I've seen on the new ac/heat systems they seem to have the same type as yours but in a hoz. mount compressor. Any thoughts?
Paul Waddell
rideair is offline   Reply With Quote
Old 06-01-2011, 11:14 AM   #33
jmpratt's Avatar
1969 29' Ambassador
Rotary compressors are made in both horizontal and vertical orientations. I used the one I did because it was available and cheap. A horizontal one will work as well, assuming it would fit.
Old 06-01-2011, 12:45 PM   #34
rideair's Avatar
I was thinking if you could use a hoz model thus it might take away the need to changed the cover and still look original?
Paul Waddell
Old 06-02-2011, 07:44 AM   #35
jmpratt's Avatar
1969 29' Ambassador
Yes, but you'd have to make sure it fits.
Old 04-24-2012, 10:53 PM   #36
1973 31' Excella 500
Flagstaff , Arizona
Thank you too Jason! Now could you drop by my place and do mine? <G>
I have an original Armstrong too, and it still works, kinda. I wouldn't get much out of it in Phoenix, but in Flagstaff it's more than adequate. But would LOVE a rebuild/refurbish job. Just too old and not savvy enough to do it. Oh well. Will keep this handy just in case.
Jocanda is offline   Reply With Quote
Old 04-25-2012, 06:10 AM   #37
1981 31' Excella II
New Market , Alabama
You must have some refrigeration experience to do all this, good job on the rebuild. I put a new Dometic on my trailer and still have the old Coleman that needs a fan motor and lots of TLC. A fan motor for mine was $150. I am sure it need the three capacitors replaced as well. I may try to get used parts and fix mine up.
Perry
Old 04-25-2012, 09:28 AM   #38
jmpratt's Avatar
1969 29' Ambassador
My refer experience is just from my tinkering. I'm an engineer, so these things make sense to me. BTW, the unit made it through the whole winter just fine! Toasty warm!
Old 04-25-2012, 05:56 PM   #39
1981 31' Excella II
I thought I smelled another engineer.
Perry
Old 04-26-2012, 08:11 AM   #40
1981 31' Excella II
Since you have gone this far, you could take the parts and make a split system and get rid of the roof box alltogether. There many folks on here that would like such a system the preserves the line of their older trailers. I expect the majority of the stuff could go under a couch or bed. Personally, I don't mind the roof top AC.
Perry
Old 04-27-2012, 04:23 PM   #41
jmpratt's Avatar
1969 29' Ambassador
Perry
I have thought about doing that, too. More because I would like to be able to service the unit without having to climb on top. If this one dies and I get a lot of free time, maybe I'll try that.
Old 05-15-2012, 10:03 PM   #42
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
jmpratt
My compliments to you on the engineering improvements you have made to an Armstrong AC/HP. I have bookmarked this thread. I have an original unit on my 66 TW and will add this to my list of planned improvements. I plan to use my 66 for another 20 years and then pass it on to another traveller.
Dan
Free 1973 Armstrong A/C parts w/shipping costs rich2002 Furnaces, Heaters, Fireplaces & Air Conditioning 13 06-19-2017 11:43 AM
Armstrong VCT - Any gluing issues with Cold? robwok Floor Finishes 4 08-08-2013 11:49 AM
A/C Cover...how does it come apart? KyMoonshine Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-10-2011 05:59 PM
Water Stains on Ambassador? MATTY J Cleaning, Stripping & Polishing 6 05-01-2011 08:28 PM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
