Old 11-09-2007, 03:35 PM   #1
1986 34.5' Airstream 345
Tyler , Texas
Rear furnace ?s
Hi! In checking the heat in my 86 345 I noticed that the rear furnace ( Suburban 16 or 20 SE) has 3 ducts...one to the water tank compartment, and 2 to grills in the wall. The front grill on the face of the unit has louvers of which only 1/2 are open. The unit sits on the floor and the front grill is 1&1/2 inches below the actual opening in the cabinet which forces air back into the cabinet rather than out into the coach. Since the front grill is open I have very little air coming from the ducts. Should all of the louvers in the grill be closed in order to force air through the ducts or should I close the ducts so that all of the heat is forced to the front grill of the furnace.
Pete
pjude is offline   Reply With Quote
Old 11-09-2007, 04:52 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
I checked mine...
Front is air intake.
Does air blow out the front on yours?
I don't have the duct to WH either...good idea though.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-09-2007, 05:01 PM   #3
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
our ducts
one blows out at the foot of the bed and one exhausts into the bathroom, not sure about the water tank but I know we did not freeze anything in 16 degree weather last January in sunny southern California!
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 11-09-2007, 07:15 PM   #4
Tyler , Texas
Furnace?
Mine blows out the front grill and not thru the ducts since all of the air goes out the grill...my question is should the front grills be closed if I want air to come out of the duct work?
Pete
Old 11-09-2007, 07:21 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Most of the Suburbans I have worked on that are used in ducted applications have a metal cover that is part of the casing that totally blocks the airflow from going out the front of the unit, thus forcing it thru the ducts.
If you open your decorative cover, you should see a metal plate totally covering the furnace. If this is missing or not properly attached, this might be the cause of your air leakage.
Old 11-09-2007, 07:25 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Ron - We are all scared with memories of that rally.
Remember, It never rains in California, it snows!
Richard
Old 11-09-2007, 08:41 PM   #7
str8strm's Avatar
Richard:
Without that snow, we never would have seen your Fire Dancer and the whole tenor of CA Streamers Rallys just wouldn't be the same. But man it was cold wasn't it?
AIR 7992
345 Rear furnace Robfike Classic Motorhomes 5 09-21-2007 06:23 AM
LP smell at rear furnace Robfike LP Gas, Piping, Tanks & Regulators 5 12-06-2006 05:44 PM
Rear Separation and Rear Sag on my '72 mello mike Axles 17 06-16-2005 01:58 PM
Furnace kooblekidz Airstream Motorhome Forums 3 11-06-2002 05:09 PM
A/C and Furnace Charles Q Treichel Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-05-2002 04:20 PM
