Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-21-2003, 04:50 PM   #1
Profile:
? re Duo Therm Furnace - 1968 GT
Question.
I light the pilot light, everything is OK. As instructed I turn the same knob to the "on" position. The pilot stays lit - BUT the burner lights up- even when the other knob, the thermostat knob is in the "off" position.
Does anyone know if this is correct? Seems wrong to me. When I turn the thermostat knob higher, the flame stays the same, now this is probably right, I think the actual thernostat cuts the burner off when it gets hot enough- the higher the setting the longer the burner would stay on.... Am I right here?
Any ideas, experience, thoughts, help????? Replacement parts???
Thank you
Bryan
Bryanhu is offline   Reply With Quote
Old 11-21-2003, 09:23 PM   #2
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Dosn't sound right
Sounds like a bad thermostat or shorted wire.
Garry
Old 11-21-2003, 09:34 PM   #3
Profile:
Gary
I would assume you can replace a thermostat? Are they fairly universal? I had the thing apart and it looks like it screws into the gas housing.
Thanks for your response.
Bryan
Old 11-21-2003, 09:45 PM   #4
garry's Avatar
Thermostat
Hmmm I was talking about the wall thermostat connects to the furnance with wires. I replaced mine with one from Home Depot compatable with RV furnance.
I have a Suburban and haven't worked on the Duro Therm.
There are several threads on furnace repair. You might do a search and get some good info.
Garry
Old 11-21-2003, 09:52 PM   #5
Profile:
Yeah, mine is as old as the hills! There is no wall thermostat, just one connected underneath the heater. No blower or anything like that.
Surburban Furnace Ills - HELP Cat Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-07-2005 08:22 AM
R & R a Suburban Furnace Janet's Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 08:19 PM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 09:29 PM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 11:11 AM
