Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 02-27-2005, 05:25 PM   #29
JeepinAudiophile
Commercial Vendor
JeepinAudiophile's Avatar
Profile:  1968 24' Tradewind
Fort Myers , Florida
Images: 66
I am planning on installing radiant heating in my 68' tradewind. I agree with over 59 that the thought of giving water access to my newly replaced floor kinda scares me. I have found an electric elements that can be laid under the flooring tiles. Of course this means you have to be plugged in to use the radiant heat. I can't remember the company that makes it, but i will rummage through my files and find the company. It would be nice to be able to use the radiant heat when not plugged in- but for me, the possibility of water damage outweighs the niceities of having radiant heating when boon-docking. --Chad--
Tow Rig: 2005 GMC Sierra Denali AWD, 6.0L HO- LOTS OF UPGRADES to help Towing (and Fun)
Trailer: 1968 Tradewind 24', Land Yacht trim (Shell-Off Rebuild and upgrades)
***Missing from my life***
WBCCI # 13657
++Take a look at my restoration photo album++
http://picasaweb.google.com/ChadsAirstream
JeepinAudiophile is offline   Reply With Quote
Old 02-28-2005, 06:20 PM   #30
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
The concern relative to water damage and the floor is, of course, a valid one. That is a primary reason I installed a Polyboard subfloor. I have been intending to install hot water radiant heat right along so the decision to use Polyboard (which is completly waterproof and rot proof) was part of that larger plan.
Electric radiant heaing solutions are available from a number of sources. I do not know for sure if there would be any issues relative to the total current required when plugged in, though. What are you anticipating your total wattage to be for your electric floor heating system?
Malcolm
malconium is offline   Reply With Quote
Old 02-28-2005, 07:22 PM   #31
markdoane
Profile:  , Minnesota
Images: 59
Originally Posted by JeepinAudiophile
. . . I have found an electric elements that can be laid under the flooring tiles. Of course this means you have to be plugged in to use the radiant heat. . . . but for me, the possibility of water damage outweighs the niceities of having radiant heating when boon-docking. --Chad--
I don't think you could get enough heat flux to do more than take the chill off. In wood (non-masonry) floors, the electric heat cable is limited to 10w/sq ft. So for a 88 sf ft area, you could only get about 880 watts (3000 btu/hr), less than a hair dryer.
Would be really nice for those cool (but not freezing) mornings, though.
Non-contributing deadbeat.
Old 02-28-2005, 07:25 PM   #32
pamelake
pamelake's Avatar
Profile:  1974 25' Tradewind
Lake Oswego , Oregon
There are several companies (Warmquest is one) that make very thin electric coils or mesh to install under wood or tile flooring. This is what I would like to do in my '74 Tradewind. Nice, quiet, even heat when you are plugged in seems nice (and not too expensive). I wonder what the problems would be? I would love to hear from someone who has done this. Thanks, Pam
pamelake is offline   Reply With Quote
Old 02-28-2005, 07:47 PM   #33
markdoane
Images: 59
Pam,
I did this in my 'indoor' bathroom. It was tile on backerboard with the wire set in thinset. It's a lot of work if done in thinset. I don't even know if thinset would work in an airstream.
If you install under a wood floor, you need to 'superinsulate' the floor, or else you lose too much heat to the belly. If you install it above the subfloor, it would need to be in grooves or between firring strips.
I used wire from http://www.warmlyyours.com/
There prices were half of what it costs at Home Depot.
Old 02-28-2005, 10:31 PM   #34
malconium
Portland , Oregon
Here are several sites that supply electric radiant heating materials.
This one has a product that can be installed under laminate flooring without any thin set:
This site offers, among other things, a low voltage system:
http://www.warmzone.com/RadiantHeat/RadiantHeat.asp
These guys were the choice of "Ask This Old House" and etc.:
http://www.nuheat.com/homeowners/experts.cfm
This company offers a lot of different sizes of standard mats:
http://www.suntouch.net/
I think in general that radiant floor heating systems require less energy than forced air systems because of the radiant heat delivery mechanism. One of the sites mentions 41 watts per square foot as being enough to keep the floor at 80+ degrees. I suggest checking the vendor claims closely before concluding that these systems are only capable of keep the chill off.
Malcolm
Old 03-01-2005, 07:31 AM   #35
markdoane
Images: 59
Originally Posted by malconium
. . . One of the sites mentions 41 watts per square foot as being enough to keep the floor at 80+ degrees. I suggest checking the vendor claims closely before concluding that these systems are only capable of keep the chill off.
Malcolm
Yeah, I'm all for that! Where did you get that number? I would believe 41 Btu/sqft, but not 41 w/sqft. I think that would curl your flooring and fry your toes.
Old 03-02-2005, 07:55 PM   #36
malconium
Portland , Oregon
Don,
You are right - it would appear that I got watts and BTUs mixed up. The following is a quote from the site listed below:
"Nuheat produces 12 watts per square foot or 41 BTU at full power producing a floor temperature of 88 - 92 degrees Fahrenheit"
The site with the above quote is:
http://www.nuheat.com/homeowners/features.cfm
Malcolm
Old 03-20-2005, 11:00 PM   #37
jerri
Profile:
Exclamation Radiant Flooring
I am new to this, or would that be rivetless.
Radiant Flooring is going great. 1/2 In pex roughed in. 300 feet in all which gives you about 3 gallons of liquid. One RV 500 modified at the factory to specs (exspensive).Rayon cutting boards milled and machined to mount the pipes into between the chassis members ( exspensive) I will do my best to get photos for you. Bubble wrap insulation with foil sides (expensive again). Work in progress.Threading 300 feet of pipe in the chassis PRICELESS!!!!!!!!!!!!!!!
jerri is offline   Reply With Quote
Old 03-22-2005, 01:07 AM   #38
malconium
Portland , Oregon
Jerri,
Sounds interesting and I will be looking forward to your photos.
Malcolm
Old 04-10-2005, 10:01 PM   #39
FranyPul
FranyPul's Avatar
Profile:
Images: 22
Warmboards radiant heat
I may be coming in a little late on this, but I'm happy to see that others have considered radiant heat and that I'm not entirely out of my mind. Have you all hear of Warmboards? They are supposed to go in like a regular base floor, have grooves cut out for piping, and all lined with, I think, aluminum. Any floor type can go on top of it. Because I have to replace my floor anyway, I was hoping to go with the Warmboards and put bamboo on top.
(no I can't afford this)
Kim
FranyPul is offline   Reply With Quote
Old 04-11-2005, 03:16 PM   #40
malconium
Portland , Oregon
Maybe no aluminum plates...
Originally I was thinking of using aluminum fins that would snap around the radiant heating tubes to help distribute the heat. Lately I have been thinking of taking another approach. I have not been able to work on my AS for a while because of other things but that doesn't stop me from thinking about various aspects of the pending remodel. At anyrate I asked a local company that supplies radiant heating things for DIY installations what they would think about just having the tubing fastened to the floor and no aluminum fins. They told me that actually the air around the tubing would work OK to get the heat distributed - it just might take a little longer.
I had originally been thinking of stapeling radiant foil insulation on top of my Polyboard floor, then putting 1x2 strips on top at about 6" on center. I was going to center the plastic tubing in between the 1x2 in aluminum fins that would span from 1x2 to 1x2. The 1x2 was going to support the final flooring. I was thinking about using some form of floating floor that could span 5" gaps. Maybe laminate, bamboo or cork. As an alternative I could envision using something like 1/4" underlayment plywood on top of the 1x2's with the finish floor on top of that (if the floor was flexible).
I was thinking about the support issue recently and it occurred to me to wonder if I really needed the 1x2 to support a floating floor if I was not going to use the aluminum fins. I went and looked at some of the PEX tubing at Home Depot and I find that it is actually very stiff. So I am wondering what would happen if I fastened down my PEX tubing at about 6" on center and just set my floating floor directly on top of it. What I do not know is how flexible the tubing would get when it warms up. It does seem like having it full of water would also help improve its crush resistance.
So my current thinking is this:
1.) Add a layer of reflective foil insulation on top of the Polyboard subfloor.
2.) Lay out my PEX tubing at about 6" on center and staple it down to the Polyboard.
3.) Install a floating floor directly on top of the PEX tubing. I might pick a variety of floating floor that has a foam or cork backer layer that could deform where the staples are that hold down the PEX tubing.
I would appreciate any feedback that anyone would have on this bare bones approach. Especially if anyone knows what the crush strength of the PEX tubing would be at temperature.
Malcolm
Old 05-03-2005, 10:34 AM   #41
stinkytwinky
1974 28' Argosy TT
stinkytwinky's Avatar
Profile:  1975 28' Argosy 28
Hinsdale , New Hampshire
Are you suggesting that one would use this in conjunction with the hot water heater?
1974 28' Argosy (Hey, Airstreams are just Argosy's that haven't been painted yet .. )
1999 Ford F250 Lariat SD Extended Cab with 7.3L Power Stroke Diesel
stinkytwinky is offline   Reply With Quote
Old 06-30-2005, 04:15 PM   #42
herbigrf
Ron
herbigrf's Avatar
Profile:  1978 31' Sovereign
Battle Ground , Washington
We have radiant heating in our ceiling of our house which is lousy. This winter I was on the internet and found two types of radiant heating that you can put in the floor. One of them was a rug with built in heating that you could plug into a regular outlet. Would be great for a trailer if you had good power access.
Ron & Christie
1978 31 ft Soverign
herbigrf is offline   Reply With Quote
floor seats and curtains remcolent General Interior Topics 9 02-18-2004 09:04 PM
radiant heat Piper Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-19-2003 11:30 PM
Mister Heater/cheap heating options? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-14-2002 03:03 PM
Catalytic Heaters - Who Wins? Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-18-2002 08:09 AM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 06:46 PM
test
