Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-25-2009, 12:59 PM   #1
Profile:  1968 20' Globetrotter
Pueblo , Colorado
Radiant furnace help
I have a 1968 Globetrotter that I have just purchased and getting started on system checks ... first problem ... the furnace burner will not ignite. The furnace is a Duo-Therm model 61603ga, radiant furnace. Pilot light lit easily but the burner will not come on no matter where I set the temperature selector. HELP and Thanks in advance.
68Globetrott is offline   Reply With Quote
Radiant Floor Heat cjohannesen Furnaces, Heaters, Fireplaces & Air Conditioning 13 09-22-2009 10:18 AM
radiant heating jerri Furnaces, Heaters, Fireplaces & Air Conditioning 62 12-22-2007 04:03 PM
Hot water radiant heat? malconium Furnaces, Heaters, Fireplaces & Air Conditioning 32 07-07-2004 03:27 PM
radiant heat Piper Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-19-2003 11:30 PM
