Old 08-14-2010, 10:32 AM   #1
ciquing's Avatar
1999 34' Excella
Fort Polk , Louisiana
Questions re: installing 2nd ac unit in rear of 34' Excella
I was just told it can't be done - since "can't" is incorrect, is there anyone out there who can tell me how to overcome the bracing issue?? I know other AS have done this, I have searched in this forum but have not encountered a similar issue regarding bracing the rear opening where power fan is located to support the 2nd ac.
Any thoughts??
Thanks!
Mona
ciquing is offline   Reply With Quote
Old 08-14-2010, 10:39 AM   #2
Any thoughts??
Thanks!
Mona
Horizontal stringers must be added and riveted to the 2 main bows that are forward and rearward of where you want to install the AC. Then 2 short stringers must be added between the stringers, and riveted to them.
Remember to also install a drain line, so that the water from the AC will not run down the sides of the trailer.
You should also install a separate "city power cable" for the second AC, as the original cable will not handle both AC's when running.
Old 08-14-2010, 10:46 AM   #3
Central , Mississippi
I guess I was to dumb to know I couldn't do it!
http://www.airforums.com/forums/f205...tml#post839907
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-15-2010, 08:07 PM   #4
ciquing's Avatar
1999 34' Excella
Many thanks! Especially for the pics - will continue to look into this, but may have questions? May I bother you again if questions arise??
Old 08-16-2010, 12:30 PM   #5
Feel free to ping me, I'm sure others here on the forum will also be glad to help.
Old 08-16-2010, 01:07 PM   #6
ciquing's Avatar
1999 34' Excella
Just a quick question, what did u use for the brace on the length of the span for the AC? Did u just use the 2x4's as the bracing? Ive been told u have to add aluminum braces on the Length sides to connect to the braces that are on the width side. Confusing huh....
Old 08-16-2010, 01:11 PM   #7
ciquing's Avatar
1999 34' Excella
Do you know any one in the Dallas Texas area that can install a 2nd A/C in the bedroom of a 34' Excella 1999? Looking to install a 15,000 BTU in the bedroom.
Old 08-16-2010, 01:11 PM   #8
Like several other folks have done, I used good solid 2 X 4's and cut them to size with the proper angle for the curve of the roof. I then screwd the inner and outer skin to the wood on 2" spacing between the screws. The wood was thn sealed with aluminum tape to keep moisture out.
Old 08-16-2010, 01:14 PM   #9
... Looking to install a 15,000 BTU in the bedroom.
Ya might wanna give that a second thought...
We went with an 11,000 BTU in the back and it only runs 1/2 the time of the 13,500 up front. With so much "off" time the humidity can start rising in the bedroom making it uncomfortable.
Now once the compressor kicks in it does cool off FAST!
Beautiful Airstream Limited 34' .. nice upgraded unit eBay Watch Airstreams on eBay 0 10-01-2009 05:40 PM
Adding 2nd AC Unit in the bedroom? TxToaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-12-2009 07:31 PM
(Inland RV) Installing new rear glass, 67' overlander questions bvanetten 1965 - 1969 Overlander 13 08-03-2008 11:51 AM
Installing a CB unit in an Airstream Classic Ramblin Boy Phone, CB & Ham Radio 1 05-03-2008 11:55 PM
Florida Unit 2nd VP SilverCabin WBCCI Forum 4 12-13-2007 11:16 PM
