Old 02-09-2008, 07:51 PM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Questioning a Duct
On my '76, 31' rear bath I have stripped out from the Kit./Bedroom wall back exposing the duct work that goes to the rear of the A/S. Just before the final outlet (aprox. under the tub), there are two, what the service manual calls Thermoflex ducts. They branch off the main heat duct and go under the floor. Does anyone know where they go and what they do?
Stone Ridge is offline   Reply With Quote
Old 02-09-2008, 08:08 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Probably to the holding tanks (black water and gray water if you have one). My '73 only has a black water tank, all the way at the back of the camper under the bathroom. There was a small, about 3", round duct from the main than ran thru the floor and into the side of the pan that holds the black water tank. The idea being that the heat would help keep the tank from freezing in winter. You probably have one near the fresh water tank as well, located just forward of the axels (I think that is where your fresh water tank is).
www.nesa.org
Air No. 6427
Old 02-09-2008, 08:12 PM   #3
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Yup, and I believe there is a certain amount of air ducted into the plumbing area under the tub etc...except I know longer have a heater...but it was eighty today so no worries
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 02-09-2008, 08:20 PM   #4
1976 31' Sovereign
1963 16' Bambi
Thank's for responding. After reading your reply I went back to the service manual and saw that there is the 3rd. duct going to the fresh water tank. It comes directly out of the furnace and immediately goes down. I haven't dismanteled the kitchen yet and couldn't see the duct. It all makes sense now. Thank you again.
disconnected duct boondockdad Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2007 05:26 PM
Duct work mark silberl Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-30-2007 02:11 PM
Heater Duct Cleaning slowmover Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-18-2007 07:39 AM
Duct to nowhere walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-17-2004 07:16 PM
Duct Tape Popup fireflyinva Off Topic Forum 10 12-05-2004 05:54 AM
