Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-27-2006, 01:41 PM   #1
jbond
jbond's Avatar
Profile:  Shalimar , Florida
Images: 13
Question on AC Drip Pan
I'm trying to install a drip pan under my Penquin AC on a 63 Globetrotter.
Does the gasket go between the roof skin and the drip pan or does the drip drip pan go next to the roof skin with the gasket on top of the drip pan?
Thanks much !
Herb
Wally# 1861
Prez VAC
63 Globetrotter Patty 62 Overlander Doc
63 Suburban Andy 63 Overlander Tex
jbond is offline   Reply With Quote
Old 12-27-2006, 01:53 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
Mount the drip pan next to the aluminum. You may want to cut out some of the excess gasket material where the drip channels cross the gasket about 1/4 of the way from the front edge.
I have heard that some dealers eliminate the gasket and just use large amounts of caulk. This may work if you never want to be able to remove it.
Non-contributing deadbeat.
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 09:52 AM
Removing Belly Pan garp Belly Pans & Banana Wraps 2 08-30-2002 01:27 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 02:35 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 09:39 AM
Tire sizing question caadoptees Tires 5 07-02-2002 11:19 PM
test
