Old 07-21-2009, 07:47 PM   #1
1964 26' Overlander
Kearney , Missouri
Question of Existing Floor Penetration 66Tradewind
I have been helping a friend with his 66 Tradewind. There is a floor penetration under the front gaucho toward the street side that we are unsure of. Does anyone know what the purpose of this is. We suspect it is some kind of vent but are unsure if its connected to the heater. Enclosed is a picture. Thanks.
64Overlander is offline   Reply With Quote
Old 07-21-2009, 09:39 PM   #2
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
There are two things that I can think of:
1, in Wally's trailers he put a an opening in the floor for ventilation. This allowed him to keep the windows closed (for noise) and open the roof vents, thus pulling the cool air from the grass in to the trailer. But 64 would have been too late to be his.
2, a floor safe. I do not hink I have seen one in a 64 but they were common in the late 80's and 90's. Could have been installed by PO. It apppears as though there was some sort of flashing around the opening (dark stains in straight line 1.00" wide..?).
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 07-22-2009, 07:20 AM   #3
1964 26' Overlander
Kearney , Missouri
66 Tradewind Floor Penetration- Unknown
Dear Drag'nwagon,
Thanks for the reply, but this is a 1966 Tradewind that I'm helping a friend on not a 1964 model. The stains are where the gaucho was in direct contact with the subfloor.
Thanks.
Old 07-22-2009, 08:06 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
If the coach has a front mounted fresh water tank, it may be a vent for your furnace. One of the advertising points that Airstream emphasized at the time was that the compartments with holding tanks received "ducted heat".
Kevin
Kevin D. Allen
AIR #827
Old 07-22-2009, 08:18 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Ice fishing.
You can make it into a Wally floor. I have one in the Caravel and it works great.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Mounting blinds in existing curtain tracks Maryw164 Upholstery, Blinds, Walls & Interior Finishes 1 05-03-2009 05:48 AM
floor question air66stream Repairing/Replacing Floor &/or Frame 2 09-30-2007 06:36 AM
Floor question AirMillie Repairing/Replacing Floor &/or Frame 2 09-28-2007 04:41 AM
Floor Question higgy116 Repairing/Replacing Floor &/or Frame 11 07-19-2006 11:25 AM
Adding a barbeque addapter to existing copper lines letsgo LP Gas, Piping, Tanks & Regulators 3 10-12-2005 10:02 PM
