Old 03-11-2008, 08:25 AM   #1
cuckooman's Avatar
1978 Argosy Minuet 6.0 Metre
scottsville , Kentucky
putting in air
i am having air put in my 78 air stream, before they cut the hole in camper, is there anything i need to know about first,
cuckooman is offline   Reply With Quote
Old 03-11-2008, 08:39 AM   #2
flamingo-kid1's Avatar
1967 28' Ambassador
Rockford , Illinois
Send a message via ICQ to flamingo-kid1 Send a message via AIM to flamingo-kid1
Ac
Originally Posted by cuckooman
i am having air put in my airstream, before they cut the hole in the top, is there anything i need to know first
vent the drainage away from your aluminum. Look at an Airstream that has it done alreadya nd don't go tot he cheapest place.. find an AS dealer.
We had our air replaced and didn't have any BUT AS do it.
I'm just a pink flamingo on the great lawn of life :-)
flamingo-kid1 is offline   Reply With Quote
Old 03-11-2008, 08:42 AM   #3
Your trailer has built in wiring for AC.
You need to find out it's exact location, as AC's are never mounted in a roof vent, in any of Airstreams products.
The location of the wiring depends on the year and model of trailer or motorhome.
If you list the serial number of the trailer, I will post the exact location of the AC wiring that's already in the ceiling.
Old 03-11-2008, 09:02 AM   #4
cuckooman's Avatar
where is this number, i have trailer number:20D8V1052 ---rob
Old 03-11-2008, 09:10 AM   #5
cuckooman's Avatar
thank you, i am looking all the time at air stream to see what kind of work has been done.
Old 03-11-2008, 09:28 AM   #6
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
-there are some HIGH qualiity airs out in the marketplace, don't settle for anything less than a mess of airs.. you need six airs to make a mess, less than six is a "covey" but reallly, who gives a flock..haha
- don't succumb to compressor depression. if you do use a ding king to remove the pinging sound while eating a king don. (why dont' they call them ding-dongs like when I was a kid?...I'm hungry...)
- you may only get one shot at this...don't blow it...up...or down...
fotochop is offline   Reply With Quote
Old 03-11-2008, 09:33 AM   #7
Darol Ingalls's Avatar
Most roof AC units are designed to fit in a 14" sqauare roof vent. Check to see if the roof vent on your Argosy is reinforced to hold an AC. You also will need a 120V power source at the opening. Condensation drains on after-market units usually drain over the roof and down the side so you don't need an interior drain tube. Of course, you get a water line down the side of the trailer. Don't let "them" (whoever they are) cut a new hole in the roof. Use the vent opening. Darol
Darol Ingalls is offline   Reply With Quote
Old 03-11-2008, 09:44 AM   #8
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Darol,
That's a bit confusing as almost all A/S have the A/C unit between the vents, not in one of them. If the pre-wire is not at the vent, why locate the AC there?
If the unit is installed and sealed correctly there is no problem with cutting a hole in the roof...unless the person doing it is a butcher.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 03-11-2008, 10:04 AM   #9
cuckooman's Avatar
thank you for the repley, yes i know i have one shot, once the hope is cut, that it---rob
Old 03-11-2008, 10:06 AM   #10
cuckooman's Avatar
thank you for the repley, i need my vent, so i have to have a hole cut---robquote=Darol Ingalls]Most roof AC units are designed to fit in a 14" sqauare roof vent. Check to see if the roof vent on your Argosy is reinforced to hold an AC. You also will need a 120V power source at the opening. Condensation drains on after-market units usually drain over the roof and down the side so you don't need an interior drain tube. Of course, you get a water line down the side of the trailer. Don't let "them" (whoever they are) cut a new hole in the roof. Use the vent opening. Darol[/quote]
Old 03-11-2008, 10:09 AM   #11
cuckooman's Avatar
thank you, i have a camper service doing the work, they are not a air stream dealer but, they service and sale other camper---rob
Originally Posted by Fyrzowt
Darol,
Dave
Old 03-11-2008, 01:55 PM   #12
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
We're mild do-it-yourselfers and installed the AC unit in a couple hours.
1. Called Andy and gave him the serial number, he gave me a measurement and a location to measure from. I cut a 1 inch hole in the ceiling at that measurement and found the wire less than a nuckle away (the wire installer was a 1/2" off).
2. I then cut the hole about 4" in diameter (about the size of an electrical box) so I could look in with a flash light, then marked, drilled the corners and cut the inside skin out, then did the roof. Installed some 2" C channel aluminum stock to reinforce the roof area, hooked up the unit, bolted it down and presto. I'm cheap I know, but wouldn't dream of paying someone to do a job that easy unless for health reasons or something I couldn't take on that project (plus I'm the one to deal with if I'm not happy with the quality of the job). Just had a buddy come by for the 2 minute job of setting the unit on the roof and even that wasn't bad. Link to our install:
http://www.airforums.com/forums/f427...day-35176.html
Only tools I used were basic stuff, good tin snips, drill, wire strippers etc and a sawzall for cutting the c channel to reinforce (could have used a hack-saw).
goransons is offline   Reply With Quote
Old 03-11-2008, 02:25 PM   #13
fotochop's Avatar
1969 23' Safari
Images: 18
OH, AIR CONDITIONING! I thought this was a jabberwocky put-on from cuckooman. "putting air" in an Airstream... must be the weather...
go with the goransons way...should be no prob..
Old 03-12-2008, 04:50 AM   #14
cuckooman's Avatar
Smile right number
hi andy, was that the right number that you wanted, thank for all the help---rob
Putting in A/C that's not already there? blondie3265 Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-03-2007 09:18 AM
Putting in New tiles kathyh53 Repairing/Replacing Floor &/or Frame 1 06-25-2006 09:49 AM
Does anyone know anything about putting safety skids on axles? 1959newbie Axles 7 05-01-2006 05:59 AM
Putting my trailer undercover Stefrobrts Our Community 32 02-05-2004 08:57 AM
Putting in new carpet wardster All Argosy Trailers 1 02-03-2004 12:02 PM
