Old 06-11-2009, 10:11 AM   #1
De Queen , Arkansas
Question Propane to Electric Water Heater Conversion
Hi all. I'm new to the forums so please bear with me. I am wondering if there is a way to convert an older model gas water heater to an electric version. I have done this before with newer models that allow you to insert the hot rod converter with little or no trouble. However, this model has the soldered valve rather than the screw off plug style drain. Does any one know of a way to do this without simply replacing the existing water heater? Thanks in advance for the help!
childst is offline   Reply With Quote
Electric Water heater on 56 Safari Rick56Safari Water Heaters, Filters & Pumps 2 04-10-2018 04:41 AM
Point of Use Electric Water Heater ? 60's Iron Water Heaters, Filters & Pumps 6 08-25-2009 09:41 PM
Water heater conversion Rae Water Heaters, Filters & Pumps 1 03-30-2008 03:59 PM
Combination propane electric water heater Pecos Pete Water Heaters, Filters & Pumps 10 03-03-2007 08:40 PM
Electric conversion to HW Heater jcramer Water Heaters, Filters & Pumps 3 03-25-2005 04:46 PM
