Old 10-15-2010, 03:28 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Propane smell
I have just removed and cleaned the Suburban furnace in our Argosy and now when I light the pilot I can smell propane there is no smell with the pilot not lit.
shepherd57 is offline   Reply With Quote
Old 10-15-2010, 03:38 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I'd check for a leak in the tube that feeds the pilot light. Probably a loose connectionon one end of the tube or the other - most likely on the valve side.
Minno is online now   Reply With Quote
Old 10-15-2010, 03:47 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
make up a solution of 20% Simple Green and spray the gas line that feeds the pilot.
Simple Green will make very small bubbles and will stick around and detect a small leak.
2004 Excursion 4x4
Old 10-19-2010, 06:57 PM   #4
shepherd57's Avatar
Lindsay , Ontario
You were right I found a loose connection at feeding the pilot. Could you tell me if there is supposed to be a gasket under the plate that goes on the outside for the fresh air intake and exhaust.When it rains I am getting water seeping in there.
Smell of propane in '81 MH Astrodokk Classic Motorhomes 7 11-14-2009 03:08 PM
Smell propane pjude Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-11-2008 09:12 AM
Is it normal to smell propane? pamelake Refrigerators 31 06-15-2007 04:41 PM
Propane smell jimmieanna LP Gas, Piping, Tanks & Regulators 19 08-19-2006 02:24 PM
