Old 04-28-2014, 05:56 AM   #1
Bbelk's Avatar
2010 27' FB Classic
Propane Pressures
How does the regulated propane pressure in the trailer plumbing compare with the pressure of stand alone appliances like bar-b-q pits and gas fire places?
Can I put a tap into one of the gas lines to power the outside toys?
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 04-28-2014, 06:13 AM   #2
dznf0g's Avatar
Oswego , Illinois
You can't use regulated gas to feed another regulator. You would need to get a control knob for your device which does not have a regulator. Or use high pressure gas direct from the AS bottle to feed the device regulator. That's what I do.
-Rich-
Old 04-28-2014, 06:55 AM   #3
1981 31' Excella II
New Market , Alabama
The pressure in your trailer is around 10 inches of water or about .5 psi. This is what an old professor of mine would call a nat fart. This won't be enough pressure to run anything that has its own regulator. As dznf0g said, I would use a Y-connector at the bottle and a high pressure hose to run to your other toys. This is a high pressure connection so you need to be careful. Always bleed the line by loosening a connection with the bottle off. Don't do this with a cigarette in your mouth. I would be tempted to carry an extra 20 lb grill bottle if you need a lot of gas for toys. This would reduce the likely hood of leaks and other mishaps that go boom.
Perry
Old 04-28-2014, 08:20 AM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My grill was designed to go in a low pressure line. Helps keep the cost down, I guess. I could have purchased an accessory hose with regulator, but I tapped into my low pressure line where the flexible hose connected to the copper pipe on the trailer and added a quick disconnect fitting. My grill came with a 3' hose and I bought a 10' extension. After I got low pressure and high pressure QD fittings all sorted out (CW sold me a high pressure QD that was marked low pressure) everything worked fine.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Sierra 2500HD tire pressures? Wingeezer Tow Vehicles 10 11-24-2008 09:10 AM
Tire and Air Bag Pressures DonaldW General Motorhome Topics 2 04-13-2008 11:27 AM
interstate tire pressures xrvr Sprinter and B-van Forum 11 09-08-2007 07:58 PM
Motorhome Tire Pressures swebster General Motorhome Topics 11 01-06-2006 08:57 AM
Tire pressures Silvertwinkie Tires 28 09-10-2004 11:00 AM
