Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-20-2006, 11:11 PM   #1
soldiermedic
Commercial Vendor
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Pre Wired for Heat 68 Safari
Greetings all,
I was looking at my roof ac unit last night and noticed that it said it was pre-wired for a heat strip. I am curious if these are easy to find for such an old model. Also was wondering if this can we wired into the theromostat. I would consider taking out my furnace as I do not forsee any boon docking in the future, but I may not get rid of it just yet.
Anyone have experience with these heat strips?
soldiermedic is offline   Reply With Quote
Old 11-21-2006, 11:19 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by soldiermedic
Greetings all,
If you have the original Armstrong TAC-110 model, a heat strip was never available.
If you have another brand or model, perhaps a heat strip is available. What make and model do you have?
Heat strips, at best, take a morning chill to task. However, do not use a heat strip if the temperature will go below freezing.
Heat from the furnace is circulated around the holding tank and water lines, to keep them from freezing, within reason.
Using a heat strip cannot perform that function, plus if the ambient temperature is at freezing, it won't begin to keep the trailer even slightly warm.
A typical heat strip puts out about 20 percent of the BTU's that your furnace does. Not nearly enough for anything except to remove a chill, sort of.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-21-2006, 03:27 PM   #3
soldiermedic
Commercial Vendor
O'fallon , Missouri
It's a dometic!
Here are pictures of the unit, a Dometic Brisk Air.
ID:	28915  Click image for larger version
Old 11-21-2006, 03:52 PM   #4
Commercial Vendor
Different kits are listed, depending on the "exact" model number.
Inlandrv.com
800-8777311
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 08:07 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Looking for ideas on a sofabed for my Safari Scotti General Interior Topics 0 09-03-2002 02:45 PM
Purchase of 73 safari april Our Community 11 09-01-2002 02:33 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 06:49 PM
test
