Old 05-21-2016, 04:39 PM   #1
1968 22' Safari
Tulsa , Oklahoma
Portable 120 AC
Has anyone ever tried to use a portable 120V AC unit? DeLonghi came out w/ a new one a little while back and it seems to be getting rave reviews from landlubbers - Amazon has trouble keeping it in stock:
http://tinyurl.com/z6y3y24
My research on these things show they draw 9.5 to 13 amps and run between 12K and 14K BTUs. Seems adequate. Most double as dehumidifiers and some offer heat pump capabilities too, though I know those are little help lower than about 40 degrees F.
I'd really like to avoid a roof unit and have to run AC on shore power in any event - I'm not using an inverter - so, what the heck? Yeah, I'll have to bolt it down and jerry-rig a vent, maybe a drain, but those seem like simple tasks.
Eh? Worth a look? What say the the grizzled ones?
Jay & Lisa
splyb is offline   Reply With Quote
Old 05-21-2016, 05:06 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
They take up a pretty big chunk of real estate inside a small trailer. The ones that have 2 hoses for air for the condenser side work better than single-hose ones, in general. I've used them in fixed locations but not in an Airstream.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 05-21-2016, 05:08 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I used an 8500 btu in 22 ft trailer. It did a good job.
CRH is offline   Reply With Quote
Old 05-21-2016, 05:14 PM   #4
1973 31' Sovereign
Middletown , California
I had a 12K BTU heat pump model that worked great in a fairly well insulated office. The exhaust was vented out the wall which means that all that volume of air had to leak in from outside, but it did work very well at both cooling and heating. I didn't pay the electric bill so I have no idea how efficient it was at making the comfort and it was a model that only had the one hose option for discharge air. I've seen some models that have the option for 2 hoses so you can choose to dump all the air from the half of the heat cycle you don't want to use and I think that would be a good feature in a lot of situations.
ijustlee is offline   Reply With Quote
Old 05-21-2016, 05:29 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Modern split units are very popular with the tiny house movement folks. Very small almost not noticably footprint inside the trailer.
MICHAEL
New Style Weber Baby Q 120 davidz71 Off Topic Forum 3 03-10-2006 08:33 PM
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 5 03-13-2005 06:20 PM
How to convert 220 AC/50hz to 120 AC /60hz brunoffrance Electrical - Systems, Generators, Batteries & Solar 5 12-28-2002 05:47 AM
12v vs 120 jane babinski Electrical - Systems, Generators, Batteries & Solar 13 09-30-2002 09:23 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
